- Jan 17, 2016
- 15,747
- 29,130
- 14 Sport
- 5.7
Alex Taylor Sets SCTA Record, Enters 200 MPH Club at Bonneville Speed Week
HOT ROD Garage’s co-host Alex Taylor traded the drag strip for the Bonneville Salt Flats as the latest driver of the HOT ROD Special 1980 Chevy Camaro.Mike GalimiWriterMarc GewertzPhotographerAug 06, 2024
See All 5 Photos
HOT ROD Garage co-host Alex Taylor has a few new lines to add on her impressive resume—Southern California Timing Association (SCTA) Record Holder and 200 MPH Club member. The young driver and social media influencer set the C/CBALT record by running a 236.182 mph qualifying pass and then backing it up the later in the day, following impound and inspection, achieving a 235-mph return run, putting her two-pass average at 235.638 mph. That outpaces the previous record of 224.331 mph, set by David Parks in September 1996. She accomplished the task while driving the “HOT ROD Special,” a 1980 Chevrolet Camaro owned by Tonya and Keith Turk and made famous through the land speed exploits of David Freiburger.
See All 5 Photos
It's known as the "HOT ROD Special" as it carries on the magazine's legacy of land speed racing. Tonya and Keith Turk own this 1980 Chevy Camaro, you might recognize their names from HOT ROD Drag Week's tech department.
It has been no secret that Alex wanted the famed red hat, which you earn by getting into the SCTA 200 MPH Club, and this goal has been several years in the making. Her and the family, led by Drag Week alumni Dennis Taylor, updated the car and have been working with the Turk’s on their record-running aspirations. The group went through the chassis, fixing and updating parts and pieces and repairing damage realized from almost 20 years of land speed racing. The car has seen its fair share of action as the chassis delivered record runs on Bonneville, El Mirage, Muroc Dry Lake, Loring (Maine), Beeville (Texas), and Maxton Mile (North Carolina). The team set nearly two dozen records with six other drivers—Freiburger, Tonya, Keith, Will Handzel, Steve Atwell, and Brad Johnson. Alex has added her name and accomplishment to one of the most storied cars in SCTA history.
See All 5 Photos
From the TV Screen to Bonneville Salt Flats
The team tapped Freiburger’s stash of racing engines for this year’s record run, selecting the C-category in the Classic Blown Gas Altered, Coupe, and Sedan (CBALT) class. The small-block Chevy was the subject of an Engine Masters, which aired on MotorTrend. The Dart-based engine displaces 347-ci thanks to a 4.125-inch bore and 3.250-inch stroke. The billet crank and billet rods are from Crower while JE Pistons custom made the slugs. The compression ratio is 11.3:1. Freiburger worked with COMP Cams on the custom grind and then added a set of Isky bushed .904 roller lifters to the potent small-block.Related: 1,100-HP Camaro Goes For A Landspeed Record
The top-end consists of AFR 227 cylinder heads (with T&D shaft rocker arms) and a Wilson-ported Edelbrock Super Victor intake manifold. The team isn’t relying on EFI but rather a CSU-modified Holley carburetor. The engine is entered in a blown class thanks to the ProCharger F-1A-94 centrifugal supercharger, which is run at 18 psi of boost. A massive air-to-water intercooler keeps the excessive heat away so the team can create as much power as possible on runs that last up to 5 miles. Freiburger assembled the engine and Dougan’s Racing Engines (Jurupa Valley, CA) handled the machine work. The longtime editor-in-chief of HOT ROD and current Roadkill host told us the setup made 1,070 hp at 7,700 rpm with EFI and a different intake manifold on Westech’s dyno, and 1,003 rwhp on the chassis dyno.
See All 5 Photos
The HOT ROD Special has been used to break over a dozen records and was driven by six people into the SCTA 200 MPH Club. The record Alex broke was set before she was born and held by David Parks, son of NHRA's founder Wally Parks.
The HOT ROD Special has seen dozens of engine combinations over the years from naturally aspirated big-block setups to ones with big superchargers sticking out of the hood. The drivetrain has been mostly consistent through those years. A Tex Racing T101A transmission sits in the tunnel and is a four-speed configuration. It is a clutchless style transmission that spins a custom driveshaft connected to a Quick Change rear housing.
See All 5 Photos
Alex is also a member of the HOT ROD 200 MPH Club, a spot she earned during the 2022 event. The team will be back on the drag strip next month for the 20th annual HOT ROD Drag Week where she will be competing in the Ultimate Iron category with their twin-turbocharged 1955 Chevy 210.
