ABeefyNoodle
The truck is a 1997 with the 5.2 engine in it I can't figure out a high idle issue with rpm bounce after touching the gas pedal it will run on its own at 1200-1500rpm but after about 10 minutes of running will just die out. I've checked all vaccum lines there's no leaks anywhere I've sprayed around the intake gasket and no leaks I have already cleaned the throttle body real good and changed the throttle position sensor, idle air control valve, alternator, o2 sensor, battery the only codes that are pulling up are transmission related P1765, P0753, P0743 would those cause the issues I'm having or have any other ideas I can try
