Logan Martin
I put in oem cam and lifters after my lifter failed and i replaced everything timing is correct but i dont think i put the lifters in the correct spot on the passanger side i got the mds lifters and i put them in the wrong cylinder and my truck won’t start without having the throttle body open and it sounds like its a harley but at 2k rpms it runs fine but wont idle or start by itself. is the lifter placement the cause of this?
