Never use Rainx???
joelmic
stl mo
2017 Ram 1500 Express Quad Cab 3.6L 4x4 20x9 Wheels
I had to get a chip filled, and my windshield is getting kinda "sparkly" with mico chips I guess...
The Windshield guy told me RainX is the worst thing for a windshield because it softens the glass? Lets even the smallest particle will leave a chip?
I dunno...
I'm about to use Glass Stripper to get a deep clean anyway.
BUT, my question: so is it okay to use a ceramic glass coating afterwards?
Is Glass stripper's Ceramic Kit okay to use?
Anything else instead?
I know this is probably "another windshield thread" but I just wanna do the right thing
2012RAM1500RT
NC
I dunno...
I've never used rain x so I can't help you there. I've had some rocks big enough that'***** my windshield that sounds like somebody shot at me and not crack but I've also had some hit me that I didn't think much about it and ended up cracking so I won't be able to help you much.
Treburkulosis
Your High End Detailer
Haslet, TX
I wouldn't mess with that mess. I would buy a bottle of this and do your exterior and glass. It will last for months. Super easy to apply and remove.
Treburkulosis
Haslet, TX
I will add this. I coat my glass with Undrdog pro or pro + depending on what I have on hand. It tends to last 4-6 months, but it eventually fails due to how often you use your windshield washer fluid. Its harsh and meant to break down bug guts so it really does a number on the coating. You could also look into this as an option as well, but just make sure you do your home work on how to clean the glass and install. You don't want to have to polish glass. It can be a PITA.
joelmic
joelmic
stl mo
I don't use it either per say... I think I bought a wiper fluid that was rainX cuz I was in a hurry.
The Windshield guy said he noticed the "beading action" and then proceeded to tell me Windshields should never get products like that. blah blah
2012RAM1500RT
NC
Lol, I have no idea what word I used that got bleeped out. Funny!
G-Ride990
Administrator
Administrator
Chandler, AZ
Softening glass? Highly doubt it. Glass is one of the most chemical resistant materials out there. Depending on what type of course. And coatings are a different story.
The only thing that comes to mind for Rainx and our trucks is I have read that we shouldn't use the orange Rainx wiper fluid because it has a tendency to clog the nozzles and crystalize or clog the pump in the reservoir.
turkeybird56
Central Texas
Correct, clogs and does a number on the sensors in the reservoir, and I'll use the adverb allegedly. I only Use the "blue" washer fluid and I always use 0 degrees F solution: I do not switch between summer and winter blends. I also have a bottle of 90% isopropyl alcohol on a shelf to dump in if the temp here gets below 0 F. Seen that once during freak storm in 2021.
Never heard of Rain-X softening glass, that's a new one.... Written on internet, gotta be true? LMAO
turkeybird56
Central Texas
Rain-X will not soften your glass. I've used it for years, both the type you squirt on and then rub in with a towel, and type you put in your washer reservoir. No issues.
I did hear, read somewhere that a "hammer" could soften the glass also, roflmao
joelmic
joelmic
stl mo
Well, I am glad this is probably pure bull$t, I expected as much since it came from a man who just fills cracks for a living.
He mentioned that RainX had an "oil" in it that made the surface soft.
I always thought RainX was nothing but Denatured Alcohol and a wax combo.
Thanks for the replies!
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
Rain-X should never be used on plexiglas, like motorcycle windshields.
Rain-X does make a plastic water repellent product that can be used on motorcycle windscreens, but their original glass treatment is not intended for use on motorcycle windscreens:
From a Harley Davidson Forum:
Just got off the phone with Rain-x. Tex was right. Started to destroy windshield the minute I put it on. The tech said to use Flitz chrome & plastic cleaner or McQuires Plas-x (sold at walmart).
He also said there is a product called Plexus by (Arrow shell.com) that the pilots use on their planes.
He said that he has heard some people have brought the windshields back. Said I have a 50/50 chance
Plexus® was developed for use in aviation, specifically for cleaning and protecting aircraft windshields and painted surfaces. Its quite simply the most effective product you can buy for cleaning, polishing and protecting all clear and colored plastics and painted surfaces.
Just thought about my old 1956 Chevy 1/2 ton
I did not have a windshield wiper motor for a period of time
I rubbed Hand Cleaner, i think it was MOJO ?? onto the windshield, rubbed it in until it disappeared.
It worked better than the OEM Vacuum powered motor
Docwagon1776
Midwest
I used Plexus a bunch. Polishing compound on old light bars then Plexus removed the cloudiness and then protected them. Motorcycle helmet visors, etc.
BossHogg
Oakland Township, Michigan
6.7L Cummins
Thinking about this, it seems if Rain-X could soften glass, wouldn't soft glass be more impact-resistant, where the softness would absorb some or all impact. A quick search of the Internet resulted in an overwhelming response of "RainX contains nothing that will etch or harm glass." It appears that detail shops spread this misinformation in the hopes of up-selling.
jejb
NW Arkansas
LOL! What will they come up with next? I use RainX after every wash and have for over 25 years. Awesome product. Unreal difference in the rain. I have a buddy that owns a glass shop, and he asked me if I used RainX when he fixed a chip in our diesel pushers windshield, as the stuff they inject acted a little funny. I said yes, and asked if that was a problem. He said no. The fix has held for years, and I still use RainX on it.
Never used the stuff you put in the WW reservoir.
