CrispyBacon
- Jun 16, 2017
- 331
- 207
- 2017
- Hemi 5.7
Anyone try the "new" wash method?
Foam canon, dwell, rinse... Foam AGAIN, dwell, second rinse/actually pressure wash carefully...
Then grit guard in the soap bucket (just in case).
I've done it 6 times, now, and every time I've poured out the water at the end, it's been clean. I do typically use a bug spray prior to the first foam, but that's it. No other pretreat.
I saw a couple of YouTube channels talking about this, now that foams have developed more. You can use higher pH soaps to do even more work during the foam stage, but they could potentially cause coatings/protection to wear a bit faster.
