Did you replace the cam and lifters because of a failed lifter and a subsequent damaged cam lobe?Anyone have insight? Just had camshaft and nee lifters installed. Now 2 days later getting P000B.
A little FYI, if you actuate it multiple times & it sounds a bit different each time; it may not actually be bad. Ask me how I know.....Was this issue ever resolved, same exact circumstance. Used original sensor. Gonna pull it today and inspect. Will probably replace with new sensor. This wouldn't be a cam timing issue would it?
