TGoedde
I got the P0307 #7 cylinder misfire error. I already install me plugs and there are no plug wires so I installed a new coil pack. Code went way but I was still getting a ping on the drivers side in one of the cylinders. Then it started sputtering and running crappy again and the same code showed up. Could this be a bad fuel injector causing the misfire? What would the code be for a bad injector or will even throw a code?
