peten95337
Hello My sons checked his 1998 Dodge 1500 Ram with the 5.2. It showed code P0455 evap leak. I checked you tube but the use a smoke tester to find leaks. I checked Harbor Freight and it is $100. Can you rent these at AutoZone or Oreilleys?
One youtube showed the rubber connector near the tank, but the part has been discontinued. He used a t fitting and hoses as replacement.
Any help or ideas is appreciated.
