jbrown5030
I noticed a kind of thunking noise a little while back that happened when decelerating. That turned into a more recognizable grinding hum and I started poking around for a culprit yesterday. The passenger side rear bearing seems to be the issue, and there’s a noticeable amount of up/down or side-to-side play in the hub (video linked below).
Do I have my diagnosis correct? Is this indeed a bearing problem?
Research would indicate that with that much play I’m probably looking at replacing the axle on that side. Is that a correct assumption?
Lastly, I’m still in a laid off and looking for work situation so I’d like to keep as much money in my pocket as I can. I’m pretty handy with brakes, suspension, exhaust and that sort of wrenching, but something about having to get into the differential to pull the axle has me thinking I need outside opinions on whether I should really leave this to a pro or if this is territory I can conquer. Thoughts?
Final question, if this is best left to pros, any recommendations on a mechanic in or near Raleigh NC?
Video of hub play
5.7, crew cab, 4x4, 3.92 if it makes a difference.
Video of hub play
