Question
MrWonderful
I recently bought a 2023 Ram with 5500 miles on it. I have the daytime running lights on. My issue is this:
When I put the truck in drive it looks like the fog lights (not sure if it actually the fog lights) come on as well, which is fine, but the passenger side doesn't come on. If I put the truck in Park those lower lights go out, again, fine, but then I can't get out and look for myself. If I turn on the fog lights, they both turn on. What is it that needs replaced, the whole unit, are there multiple bulbs and just one of those needs replaced? I can't find anything about it.
Jrod
USAF 1997-2008
Virginia
2024 Laramie Night Edition
HEMI 5.7L eTorque
No idea how the 5th Gen LED light system works yet. Since I just got into one last week. But worst case scenario, your truck is still under factory warranty. The dealer is still on the hook to resolve any issue.
1979 300
Southeast PA
6.4L
If your steering wheel is turned it will turn on the fog light on that side, or if you go below 25 MPH and hit the turn signal, that side fog light will come on. Is your steering wheel straight when you are checking the fog lights?
mikeru
Super Moderator
Super Moderator
The Palouse
2020 Limited
Hemi 5.7L non-Etorque
The fog lights on 5th gens double as cornering lights. Turning the fog lights on disables that feature (obviously).
DA67Goatman
Ohio USA
set the parking brake and you can get out and check them yourself in drive or reverse with the key on engine off.
