B4DR4M
So I had my truck recently in the shop for these same issues and I also had to have the win module replaced as well as a new key fob reprogrammed. I’ve used Alfa obd for the reprogramming. Truck ran like a champ with no issues but as soon as I try to go start my truck it’ll still have the service 4wd light on, traction control light on, the lightning bolt for the throttle body and it’s causing the truck to constantly crank but will not run. Anyone ran into anything similar or have a idea of exactly what should I narrow this down to? Gets frustrating when you worry about if your truck will start the next go around.
