WilliamS
Built for plug and play on Quads, will work with Duals with a relay for the high beam switch (duals will need quad headlight stock harness).
Just finished these in time to trade in the truck. They are built off repo duals so I could fit the giant D2S bixenon projector and rgb halo. They have Morimoto 5k bulbs, power house 35 watt to 55 watt on high beam ballasts. All the hardware needed to run the halos through your phone on bluetooth with a free app. As well comes with not pictures 2 waterproof strips that connect to the halos that can be used as accent lighting that also chase and color change. I used morimoto sealer on both, then went around that with clear silicone to seal them the very best I could. One headlight has a small rub mark that will buff out.
Comes the canbus resistors, wiring for high beam for ballast connection and hi/low shutter for projector as well. The caps are setup for all the wiring.
Only things needed will be the harness from your stock quad headlights. Once you remove the stock headlights the harness between the truck and the headlight will be used to power this setup. Is 100% plug and play.
Im thinking $500 shipped to the US, I wont ship out of the continental US, dont ask, isnt happening.
![62df353eebbfae0fc51935535ae19f4f.jpg 62df353eebbfae0fc51935535ae19f4f.jpg](https://www.ramforum.com/data/attachments/399/399057-df1f596f99ebf94a8e0a32fc0fed3bb1.jpg)
![150079e4d0220d28d0ef2d0f6bb2bbf8.jpg 150079e4d0220d28d0ef2d0f6bb2bbf8.jpg](https://www.ramforum.com/data/attachments/399/399058-32ba1d128979b50f8d7f7ea4c3fa7baf.jpg)
![ac32a425d8251a8008c7c6ed658d5b8c.jpg ac32a425d8251a8008c7c6ed658d5b8c.jpg](https://www.ramforum.com/data/attachments/399/399059-2ee69207716123218d229a401a814ddb.jpg)
![5c8555f90a8fdf87901ccf165ae2be73.jpg 5c8555f90a8fdf87901ccf165ae2be73.jpg](https://www.ramforum.com/data/attachments/399/399060-610fae854c92b71d4c1a10e104e2b3b2.jpg)
![f2e04c6eeaf3a0d1eab58b4a08bbd7a0.jpg f2e04c6eeaf3a0d1eab58b4a08bbd7a0.jpg](https://www.ramforum.com/data/attachments/399/399061-92459a4c63149a8fcf06fd8ef463bd26.jpg)
![153bb2ea1f76fd8ad2988261109ec7d8.jpg 153bb2ea1f76fd8ad2988261109ec7d8.jpg](https://www.ramforum.com/data/attachments/399/399062-86d94f0b9844bb4fca920505350745fc.jpg)
![754ca018ea4151351c3f8102af6dbb4e.jpg 754ca018ea4151351c3f8102af6dbb4e.jpg](https://www.ramforum.com/data/attachments/399/399063-30465eee6871cdfa342dfd0eeebdcd9c.jpg)
![e1a26608a460fda846137a1c5f9b90a3.jpg e1a26608a460fda846137a1c5f9b90a3.jpg](https://www.ramforum.com/data/attachments/399/399064-d327e5f002529bde42b65b7d52757386.jpg)
![4bf6444a9f83408c9999cde88b3dd4b9.jpg 4bf6444a9f83408c9999cde88b3dd4b9.jpg](https://www.ramforum.com/data/attachments/399/399065-5d089f5fba04bdf35767199693f98f40.jpg)
![58036e863d6a175428bc081043223851.jpg 58036e863d6a175428bc081043223851.jpg](https://www.ramforum.com/data/attachments/130/130919-f76d805a3735532d1cc066b1c380eadb.jpg)
