liRam22fl
hello I tried to change out my bulb and they left driver side tail light still doesn't work does anyone have any suggestions. 22 ram big horn
The lights on new vehicles are not directly controlled by the switch, anymore. Instead, the turning on of the headlight switch sends signals to the Body Control Module (BCM). Inside the module are microprocessors that do the actual deed of providing current to the different lights.hello I tried to change out my bulb and they left driver side tail light still doesn't work does anyone have any suggestions. 22 ram big horn
Have you checked your fuses for the tail light?
Didn't realize that....just made an assumption. I even looked at my fuse box under the hood and yup, no fuses for any lighting.There are no fuses for the lights, they are all controlled by the BCM (have been for many years).
OP, do you have a multi-meter to confirm there is no voltage at the socket? Visually inspect the wires and if all else fails try the dealer (assuming you are still under warranty)
