Fatcat1993
Having a starting problem on my 2014 ram 1500 big horn edition 2wd truck. Throwing code p0850 but I'm getting mixed reviews from some saying the transmission range sensor is bad to the park/neutral safety switch is at fault. Also I've been told it could be the pcm or a short in some of the wiring. I had just started the truck up after leaving the autoparts store. Made it out of the store parking lot and the truck cut off. Hasn't been able to start since. Any suggestions as to which direction I should take would be appreciated.
