2.5 lift, now CV joint throwing grease
lighthawk
US
gas 6.4l
New 2021 RAM 3500 with less than 2k miles with approximately <100 miles in 4wd. We just took the truck on a 700 mile loop through Nevada with our FWC camper.
The only mods from stock are 35" tires and a 2.5" leveling kit.
I did an inspection today, and found the CV joint from the front drive shaft has been spewing grease all over the place. Do I have a failure going on here? What should I expect from the dealer?
CLOUDL1GHT
Lone Star State
Cummins HO
Just at first glance it definitely looks like a boot or seal failure. No noise coming from the front end that you can tell? The joint itself is probably fine. I would take it in but be prepared for them to blame the leveling kit for it...
Dean2
Near Edmonton
Take it in a get it fixed. If they try to blame the leveling kit, ask them why Dodge dealers install them all the time if it creates these problems. The issue is NOT the leveling kit, you have a bad boot or joint. Get it repaired before something worse happens.
lighthawk
lighthawk
US
gas 6.4l
Thanks for the feedback
I heard a few squawks from the front end when we were driving irregular potholed trails on our first day. It seemed to quiet down the next two days, which included some rough driving. I attributed it to "things getting settled".
Good point about RAM installing their own lift kits.
I'll contact my dealer on Monday and get a service appointment.
I'll report back what they say.
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
What 2 1/2” kit did you use and did you install a new track bar and get the alignment done after the install?
lighthawk
lighthawk
US
gas 6.4l
It was a Rough Country 2.5" lift. I wasn't sure about it, because it was composite (not disclosed on their website) and yes, my mechanic did a full alignment afterwards. I did not install a new track bar.
I'm trying to understand the geometry here. If the body is lifted, does that change the relationship between the transfer case and the front axle?
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
Yes and anything 2.5 and above need a new track bar. It’s a brand new truck I would highly recommend getting the rough country stuff off. Icon makes a really nice leveling spring for the front @Nick@GotExhaust can set you up with the icon coil springs and a new track bar. Otherwise it’s going to get really expensive down the road. You lucked out noticing it when you did
Nick@GotExhaust
Preferred Vendor
SC
I agree get that RC kit off there. They are cheap for a reason, they are low quality and do not lift the truck reliably. The ICON kit mentioned above is a great quality kit and lifts the truck correctly while providing a smoother ride. The track bar is a must at 2.5" of lift. The ICON springs and trackbar will accomplish the lift you want while not damaging other parts of your vehicle like some other methods can/will. Message me for a quote on anything.
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
The blocks you see in the kit above is for the rear sway bar endlinks because when you lift the front angles everywhere change. Rough country is quick to push products out because it looked good on a computer screen never made it onto a truck in an r&d setting
lighthawk
lighthawk
US
gas 6.4l
I just want to close out this thread and report back.
The dealer replaced the front drive shaft under warranty. Truck only has 2500 miles on it. The service guy made some reference to the possibility the boot may have been punctured. With the skid plate right there it seems like that's a fairly remote possibility.
In any case, I'm ready to go for some Eastern Sierra trips this month, and several weeks in Death Valley next month.
Dean2
Near Edmonton
Glad that worked out well and from the sounds of it no guff from the dealer.
