2007 Mega cab 6.7 cummins
bobby a
Detroit
cummins 6.7
Hi, Ram owners, I am new to this forum and not really sure how to navigate this forum. I have a lot of questions, I will start off by saying I do love my truck. I am the original owner and I keep the truck in mint condition. I have sunk so much money in this truck for various things including 3 Particulate filters changes and a turbo or two and multiiple other things. It is currently in the shop for 2 things. First, a check engine light came on during a freeway trip to Tennesse from Mi. Had a diesel mechanic pull the code and it read 2 codes, P000F and P1011. We changed the fuel filter because it was the cheapest and easiest and the check engine came back on about 50 miles after it was replaced. We were 300 miles from home pulling an RV, we kept driving because there was no loss of power and the engine seemed to be running fine and the light was not flashing. Than all of a sudden the display started reading particulate filter 90% full, we were freaking out. We kept driving and display kept saying 90% full. We drove about 50 miles on the freeway and pulled into a rest area for about 30 minutes to gather our thought. We decided to chance it and keep driving. When we got back on the freeway a few minutes later the display started reading re gen in process 80% full than 70% than re gen complete. I don't know what to make of all this and I am really getting tired of spending so much money on my truck that I love. It is a very nerve racking situation with this going on and we are pulling a 40 foot 5th wheel with limited places to stop and park. Can someone help please??
Thank you,
Bobb A
Andersoncma
Utah
6.7L Cummins
Thank you,
Bobb A
On my 2011 Ram2500, 6.7L Cummins I removed the dpf, and run it with no codes w H&S Mini Maxx
B
bobby a
Detroit
cummins 6.7
Thank you both, I have no idea what that is that you have done to your truck. I have heard of removing the dpf but was told that is a no no so I just discounted it. My truck is all stock except for a Banks cold air intake. I guess I should mention this diesel only has 155K miles. I am waiting for the dealership to call and let me know what parts need to be replaced this time. Again, I love me truck but don't love all the money I have sunk into it. I suppose I should of found this forum many years ago, I may be more knowledgable of what to do with my truck when things go wrong.
Oliver Closehauf
Cincinnati
2005 Laramie
Cummins 5.9
Do you have to do inspections to get your tags?
As I understand it, the regen process is an automated cleansing of the particulate filter. Once the filter gets clogged to a certain point your engine will go into regen mode. The filter is superheated and all of the crap gets vaporized. I don't know how its done.
I would expect this is explained in your owners manual. I don't have any first hand knowledge of regen, just what I've read about it here on this forum. I'm kind of surprised you have not seen this before now.
HemiLonestar
MD
Considering recent EPA activity in the past year or so, I wouldn't proclaim that too loudly. They're mainly going after the professional tuners but how long before they get greedy and pounce on random people?
Smokeybear01
US-NW Coast
Cummins 5.9
I'm ignorant of the regen process, but on my 5.9 there is a bleed off on the fuel filter housing. You may have a tank of dirty fuel that regular bleeding will keep on top of. And then again, I know nothing. Welcome to the forums and good luck with your baby,
B
bobby a
Detroit
cummins 6.7
thank you for those that have chimed in. The regen is suppose to happen automatically when it get full and to drive at 45 miles an hour for 20 minutes or something like that. My puzzlement is that when my regen appeared on the displace, I had been driving on the freeway pulling a 5th wheel. I know this should of not come on. Another puzzlement is that it did not start the regen process till after I stopped in a rest area for about 30 minutes and then when we got back on the freeway thats when the display stated it was in the regen process.
On a different note, as I stated in my original post the check engine lite came on way before the regen issue ever started. I got my truck back from the dealership yesterday and they are kinda puzzled as well. They kinda equate both issue with me going through the mountain pulling the 5th wheel and said something about a fuel pressure switch was doing it job because of going through the mountains and pressing down to get more fuel, they sais its a safety feature. Not sure if I buy all this. I really would like to hear from owners that have the same year as mine so we could compare notes. Please keep your suggestions coming. I have no ware else to turn.
Thank you all,
Bobby A
Andersoncma
Utah
6.7L Cummins
Yes, very good point!!
B
bobby a
Detroit
cummins 6.7
You guys are right, I should of removed the dpf years ago like so many did, I could not find a shop that would do it since it kinda was a hush hush thing. I was just in hopes that Chrysler would just fix the problems. There is a Cummins shop near me, I may go up there and see if they can give me any ideas. Thank you all for posting. Post #11 I just now seen your post, thank you for sharing that, I will check into that, thanks very much.
MADDOG
Out Exploring Arizona
Yeah, my 2017 went into limp mode 3 different times within the first 4000 miles of use, usually with me being 14 miles North of NoWhere. Each time it was towed to a dealer.
All the dealer(s) could do was clear the code and send me on my unmerry way.
With just a bit over 4K miles on the truck I had a full delete and tune done to it. No more issues were experienced.
B
bobby a
Detroit
cummins 6.7
Yes, I feel your pain Michael, I have experianced the limp mode a few times myself. I think the first time the truck only had 750 miles on it.
Fuel35 67
Hanford
Seems as though Michigan doesn’t do emissions testing and no annual vehicle inspections. That could one something to think about.
B
bobby a
Detroit
cummins 6.7
Yes I hear ya, I wish I could find a shop that could fix my truck once and for all.
1BADDREAM
St. George, Ut
2007 Megacab
Thank you all,
Bobby A
Did you ever get any more issues with this? I have the same truck and have had the same codes but I have deleted the DPF and EGR cooler.
68PowerWagon
Dayton, Ohio
2022 Laramie 3500
6.7 CTD
If it were me & I was past warranty as you are, I would look to do this as well. I am not one that does a lot of mods like this, but every time I hear owners say they are having problems with the early emissions systems, as soon as they delete, all their problems go away. And the icing on the cake is they get better performance & better mileage. It will be difficult to find somebody to do this as it is illegal & they are busting the bigger shops who perform this service. So you will have to find a shop that will give you the wink & nod. ;)
DJTC45
Tennessee
I bought my Dodge Ram 2500 4x4 ST 6.7L Diesel new in 2007 with 23mi on the OD. I had problems at about 100mi 23 check engine lights in a three week period. They replaced the Turbo on the last visit for the check engine light, I had a good conversation with both of the dealerships Diesel Mechanics that were working on my Truck. Both told me to loose the emissions components, well I came home and ordered everything I needed to do the deletes. I waited for awhile before I decided to jump in and do it. When the Truck hit 18,000mi I pulled everything off and bought a SMARTY JR Tuner with the ME TUNING and never went back there until I had 195,670mi on it and the Transmission went out, I had them order me a new one and insall it and they did. I've done a few more mods. on it lately. Did the CCV Filter delete and Installed an Aluminum Valve Cover and new Rocker Box from G&R Diesel, a Banks Monster Ram Intake and new open air Plenum to get rid of the restricted grid heater that has the bolt that can come loose and fall into your engine. I just Installed a RevMax Zero Flex Valve Body, new filters and bought a PPE Spin on Filter that has a steel Nippele instead of that plastic one that broke and caused my first Transmission to take a crap. Tonight I pulled the TCM off and a new one will be here tomorrow, it went into 4th gear limpmode last month before I did the RevMax Valve Body upgrade along with a new Selonoid Pack and new sensors. I hope that will fix it, Did the relearn and was driving it to break everything in and it started the 4th gear limpmode again. The local Transmission shop just up the road from me said that they have had to replace several on the 6.7 with the 68RFE. Doing all the deletes was the best possible thing for me to do since we don't have emissions testing were I live.
