2010 Dodge Ram Seized Need to Swap Out
DenverCORamOwner
Denver
Hi,
My engine seized on my 2010 Dodge Ram 1500 5.7 Hemi. Oil Sensor had gone off, swapped the sensor at the parts store thinking that was the issue. Needless to say the truck stalled one mile before getting home. My guess is the oil pump went out, then after my inadequate response, the engine seized. I tried turning the main crankshaft pully with the 22m and breaker bar. Does not move at all.
Cost. Ideally, I would love to have the $3600 to get a refurbished crate engine. At this point I only have 2k and need to find other way to do this.
I've been looking for replacement engines from a salvage car or even a junk yard:
  1. I have read on some forums that the 2010 Dodge Ram Hemi 5.7 might be compatible with a Dodge Ram 1500,2500,3500 as far up as a 2019? But I have read a lot about MDS and other things to look out for.
  2. What other cars might have a compatible engine, I had previously replaced a head on this engine from a dodge charger with a hemi. Might I be able to get a HEMI from a DURANGO or other vehicle?
  3. Any other advice you can provide that can be helpful.
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
If i recall correctly, 2500 & 3500 Rams 5.7L, did not have MDS before 2018
When & IF you decide to do an engine swap
set both the current engine & the replacement engine side by side
switch over any sensors that look different onto the replacement engine,
unless the sensors are for the MDS & the replacement engine is not MDS
The intakes may or may not be different
one or two sensors may also control the MDS
don't throw away any parts of any kind, until the new engine is running as it should
Read up on the different sensors
jws123
nj
You can use a hemi 2009 4th gen-2012 or 2013+ however you will have to swap the tone ring on the crank and timing cover its a pain in the ass just did one you have to remove the crank to swap tone ring from old engine.
