2011 1500 5.7 Hemi .. Cranks but no start
sinram84
Virginia
Hey all 2011 1500 5.7 hemi
Problem
Cranks but no start
Description
Turn key on hear electrics come on and click.. but I don't hear fuel pump prime .. turn key to start and engine only turns over
through friend suggestion I have replaced the fuel pump and crank sensor and cam sensor
Please help I don't want to spend more than I have to and I don't want to take it to a shop
Travelin Ram
Replacing parts based on guessing games and suggestions is expensive. Diagnosis first, repair second. If you buy aftermarket parts, they may be faulty and further conceal the original problem.
First things to check, is it spark or fuel system?
Could be fuel pump, pump relay, or fuse; the place to start is does the pump get power, and is there fuel pressure.
Spark testers aren’t expensive, or you can simply pull a plug.
Daw14
Any codes ? Fuel pump relay ?
S
sinram84
Virginia
No codes I learned last night that the relay in the tipm fails or goes bad so I ordered the relay jumper gunna try that and cross my fingers
jws123
nj
