chris444455555
2013 ram 2500 5.7 gas 210 000 kms
very bad hesitation when accelerating at low speeds from a stop always around 20 to 40 km speeds no issues on highway or if i floor it, it takes off
i have no engine codes other then a low voltage on gas pedal but i replaced it code still remains
i have replace plugs , checked cleaned air intakes and mas, did a compression test
any ideas would be much apricated thanks i have taken the truck to 3 different shops and none of them have any idea one said maybe its a bad valve body but not sure
