ram1500rsm
- Jul 24, 2018
- 4,823
- 5,291
- Location
- Trabuco Canyon, CA
- 2014
- Hemi 5.7
Yep, 1.5" rear driver should do it. if you wanted even more level front to back you could also add a 0.5" in the front driver strut if you have standard travel struts. If you have CO's you could put 2 more turns in the front driver side.So topped off the gas tank completely and here's what I got (measuring from ground to top arch of wheel well) ..keep in mind, my newer tread tire is on the passenger front currently, so circumference may be adding a hair or two to measurements:
LF - 37 21/32
RF - 38 13/32
LR - 38 23/32
RR - 40 19/32
So in other words, I have ~ 3/4" lean on the front towards the driver side and ~ 1.875" lean on the rear driver side (full tank of gas)--which would also explain the ****** off girlfriend every time she hops in the truck haha.
Im guessing a 1.5" spacer tossed in the rear driver corner will level it out (still would have ~3/8" lean but i can live with that/still load the passenger side of the truck heavy to compensate.
Does that sound correct?
Have fun.
