2017 1500 Laramie Longhorn - New Member
TxStyle
Just bought this 2017 1500 Laramie Longhorn a week ago. Finally got another truck - first one was a 1999 Silverado Z71 Extended Cab 4x4. Had lots of cars since, but this one is quickly becoming my favorite. The view from up here is pretty good. Im including the build sheet supplied by Ram Customer Asst ... talk about a fast response... wow.
[/url]FullSizeRender (10) by Marcus Roberson, on Flickr[/IMG]
Thank you for contacting the Ram Customer Assistance Center in regards
to your 2017 Ram 1500.
We are pleased to provide vehicle build information per your request.
According to our records, your vehicle was equipped from the factory
with the following:
Sales Code Description
*DJ Premium Leather Bucket Seats
-U1 Canyon Brown/Lt. Frost Beige
APA Monotone Paint
BABS 160 Amp Alternator
BCNS 730 Amp Maintenance Free Battery
BNBS Electronic Stability Control
BRTS Anti-Lock 4-Wheel Disc Brakes
CACP Bucket Seats
CADP High Back Seats
CAJP Ventilated Front Seats
CBFS Premium Door Trim Panel
CB9S 2nd Row In Floor Storage Bins
CGDS Front Height Adjust Shoulder Belts
CGSS Supplemental Side Air Bags
CG3S Advanced Multistage Front Air Bags
CJ1S Supplemental Frt Seat Side Air Bags
CJ2P Supp. Side Curtain Frt/Rr Air Bags
CKES Carpet Floor Covering
CLZS Luxury Front & Rear Floor Mats
CL2P 4 Adjustable Cargo Tie-Down Hooks
CMAP Heated Front Seats
CSPS Driver/Passenger Assist Handles
CSXP Rear 60/40 Split Folding Seat
CUES Rear Underseat Compartment Storage
CVNP Folding Flat Load Floor Storage
CVTS Full Length Prem Upgraded Floor Cons
CV2S Overhead Console w/Garage Dr Opener
C1HP Rotary Shifter-Bright
DBAC All Automatic Transmissions
DFK 8-Spd Auto 8HP70 Trans (Buy-US)
DH8S Elec Shift On Demand Transfer Case
DJGS 215MM Front Axle
DMCS 3.21 Rear Axle Ratio
DRNS 235MM REAR AXLE
DSA Anti-Spin Differential Rear Axle
DS7S Conventional Differential Frt Axle
EZH 5.7L V8 HEMI MDS VVT Engine
GACS Tinted Glass Windows
GBBS Tinted Windshield Glass
GFA Rear Window Defroster
GFES Rear Power Sliding Window
GNCS Sun Visors w/Illum Vanity Mirrors
GNKS Rear View Auto Dim Mirror
GNZP Auto Dim Exterior Mirror
GU4S Power Multi-Function F/Away Mirrors
GVBC All Vehicles W/Power Mirrors
GWA Power Sunroof
GXDP Remote Proximity Keyless Entry
GXMS Remote Keyless Entry with All-Secure
GXXS Sentry Key Theft Deterrent System
GX4S Keyless Go
HAFS Air Cond ATC w/Dual Zone Control
HGBS Dash Liner Insulation
HGFS Floor Tunnel Insulation
JAXS Laramie Longhorn Instrument Cluster
JCBS 120 MPH Primary Speedometer
JECS Longhorn Interior Accents
JFJS Temperature & Compass Gauge
JHAS Var Intermittent Windshield Wipers
JHCS Rain Sensitive Windshield Wipers
JJBS Dual Note Electric Horns
JJJS 12V Auxiliary Power Outlet
JKVP 115V Auxiliary Power Outlet
JKYS Power Accessory Delay
JLNP GPS Navigation
JLPP GPS Antenna Input
JPBS Power Locks
JPWP Power Lumbar Adjust
JPZP Heated Second Row Seats
JP3S Pwr Front Windows, 1-Touch,Up & Down
JRFP Pwr 10-Way Mem Drvr 6-Way Pass Seats
LADS Premium Taillamps
LAXS Front Passenger Seat Belt Alert
LAZS Vehicle Information Center
LBCS Glove Box Lamp
LB1S Front Door Accent Lighting
LB2S Rear Door Accent Lighting
LCJS LED Interior Lighting
LDAS Underhood Lamp
LEBP Ext. Mirrors w/Supplemental Signals
LECP Exterior Mirrors Courtesy Lamps
LEMP Exterior Mirrors w/Memory
LENP Chrome Exterior Mirrors
LERP Power-Folding Mirrors
LETS Traveler/Mini Trip Computer
LEUP Auto Dim Exterior Passenger Mirror
LEVS Radio/Drv Seat/Mirrors/Pedals Memory
LHES Rear Dome w/On/Off Switch Lamp
LMCS Bi-Function Projector Chrome H/Lamp
LMGS Automatic Headlamps
LMSS Auto High Beam Headlamp Control
LNJS Fog Lamps
LPES Cargo and CHMSL Lamp
LPLS LED Bed Lighting
LSAS Security Alarm
MBFP Bright Rear Bumper
MCMS Body Color Upper Fascia
MCTP Bright Front Bumper
MDAS Front License Plate Bracket
MDXP Active Grille Shutters
MEDS MOPAR Bright Door Entry Guards
MFJP Chrome Grille w/ RAM Letters
MGAS Ram's Head Badge
MHLS Rear Wheel Well Liners
MMEP Chrome Belt Moldings
MMLP Body Color Fender Flares
MNES Body Color/Chrome Door Handles
MPLS B-Pillar Black out
MRTP Chrome Tubular Side Steps
MUSS 4X4 Badge
MW5P Hemi Badge
MXCS Front Bumper Sight Shields
M1BS Longhorn Badge
NAS 50 State Emissions
NERS Dual Rear Exhaust w/Bright Tips
NFXS 32 Gallon Fuel Tank
NHDP Heavy Duty Transmission Oil Cooler
NHEP Engine Oil Heat Exchanger
NHJP Exterior Mirrors w/Heating Element
NHMS Speed Control
NHNP Electronically Controlled Throttle
NHSP Heated Steering Wheel
NMCP Heavy Duty Engine Cooling
PW7 Bright White Clear Coat
QW7S Bright White Clear Coat
RAAC All Radio Equipped Vehicles
RA4S Uconnect 3C NAV with 8.4" Display
RC3S 9 Alpine Speakers w/Subwoofer
RDDP Fixed Long Mast Antenna
RDZP Steering Wheel Mounted Audio Ctrls
RE8P HD Radio
RFLP 8.4" Touchscreen Display
RSDP SiriusXM Satellite Radio
RSMP SiriusXM Travel Link
RSSP SiriusXM Traffic
RSUP Audio Jack Input for Mobile Devices
RSXP Remote USB Port
RS3S Remote USB Port - Charge Only
RS6P Media Hub (USB, Aux)
RS7P Uconnect Access
R04P All VP4 Radios
SBAS Power Rack and Pinion Steering
SC3S Premium Leather Wrapped Steering Whl
SER Air Suspension, 4-Corner
SFBS Front Heavy Duty Shock Absorbers
SGBS Rear Heavy Duty Shock Absorbers
SHAS Front Stabilizer Bar
SHFS Rear Stabilizer Bar
SUAS Tilt Steering Column
TBBS Full Size Spare Tire
TBMS Tire Carrier Winch
TTNS P275/60R20 BSW All Season Tires
TZAP Goodyear Brand Tires
WLZC All Aluminum Wheels
WMJP Center Hub
WRJP 20X9.0 Alum Polish/Silver Inserts
W1DS 20" Full Size Steel Spare Wheel
XACS ParkView Rear Back-up Camera
XAGS ParkSense FT/RR Park Assist System
XAMS Power Adjustable Pedals w/Memory
XBMS Remote Start System
XBNP Tip Start
XB9 RamBox Cargo Management System
XEAS Tow Hooks
XFCS R1234YF A/C Refrigerant
XFHS Class IV Receiver Hitch
XFKS 7 Pin Wiring Harness
XFUS Trailer Tow w/4-Pin Connector Wiring
XGDS Universal Garage Door Opener
XGMP Tire Pressure Monitoring Display
XHC Trailer Brake Control
XJJS Locking Tailgate
XJ8S Body Color Fuel Filler Door
XKDS 'Why Buy' Label
XLNS English/USA Language
XMCP Bed Cargo Divider/Extender
XMFS Spray in Bedliner
XRBP Integrated Voice Command w/Bluetooth
XXTP Humidity Sensor
XXUP Electronic Shift
XZNP Raised Ride Height
X8ZS Seat Parts Module
X81S Instrument Panel Parts Module
X82S Door Parts Module
X83S Front End Parts Module
X88S Tire & Wheel Parts Module
X9BP 1-Yr. SiriusXM Radio Service
X9EP For Details, Visit DriveUconnect.com
X9HP For More Info, Call 800-643-2112
X9KP 1 Yr. Trial (Registration Required)
X9MP 5-Year SiriusXM Traffic Service
X9NP 5-Year SiriusXM Travel Link Service
YAAS Build To U.S. Mkt. Specifications
YEP Manuf Statement of Origin
Cmsharp
Rogers, AR
I think you have plenty of options on that thing! Looks great congrats.
Curlyp
OH
Congrats!
BigBlackHorn
Sounds like a nice truck. Congrats and welcome.
axhoaxho
Congrats! Truck looks great, and I am starting to like the new grill.
unxpctd
Minnesota
2021 PW 75A
Very sharp...!
Never been much for white vehicles but that is nice looking...and my local dealer has a white Sport on the lot...had to take a second look or two.
Ram's look great in white!
Nick@GotExhaust
Preferred Vendor
SC
Congrats and welcome. Nice looking Ram you got there.
Any mod plans?
JB1
Houston, Texas
Welcome, congrats on the new truck
TxStyle
TxStyle
The Scoop on the truck
Thanks for the welcome. It's funny but there are things on the truck that arent on the list like the 4-corner air suspension and the RamBoxes. I figure that must be the local option package or something.
I replaced the antenna with a Stubby but I am disappointed with the reception. Lucky for me the Sirius 1 year subscription is in place while I figure something out.
I'll likely do a BakFlip G2 next. I am a pretty much "stock with embellishments" sort of guy especially at the cost of this thing. Here's the window sticker as an example of the stuff I mentioned.
[/url]2017 Ram 1500 Laramie Longhorn by Marcus Roberson, on Flickr[/IMG]
