2017 ram 1500, nothing happens when I turn the key
Kanechet
Canada
Hi, first post here. Looking for some insight or possible starting point for figuring out what's wrong with my truck. I started when I was driving and all the instruments on my dash started going crazy, windscreen wipers came on, every possible light was on and my speedometer was dancing etc. I lost traction control and cruise control. I pulled over to turn it off and turn it back on to see if that would help. When I went to try and start it again, nothing happened, the gauges twitched a bit but that's it, wouldn't do anything, couldn't roll windows up or change in to neutral to push it. Any help is appreciated
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
You can easily put the Ram in Neutral
there is a panel where your E Brake release handle is
There is another panel just above it
Open the second panel
You will see a red strap handle
unhook the handle off the loop
if you look at the device where the strap attaches
you will notice a little locking device
Pushing on that device with a key or screw driver should release it as you pull on the strap
turkeybird56
Central Texas
Everything going crazy: Electrical.
1) Battery (#1 cause of issues, bad battery and/or bad ground). U have 2017 Truck, these new batteries not last forever, 1st to check.
2) Loose/badly connector interior connected. On floorboard, firewall, above to left of brake pedal to the right of E Brake: There are 1-3 white connectors: All the major wiring runs through those. Check and make sure they are all properly connected and locked closed.
3) There is a connector like on firewall under frame, truck, slightly fwd of drivers seat that can become unconnected. That would be the 3rd thing. After that, trip to good mechanic or dealer, IMHO...
GTyankee
3.0 ecodiesel
Hopefully it is not the Ignition Switch itself
They are not cheap & they need to be programmed
There are several Youtube Videos that cover the 2017 Ram ignition switch
Rado
US NAVY VETERAN
Maine
Pentastar 3.6 V6
Any Updates on what you found ?
Thanks
K
Kanechet
Canada
Going to mess around with it today after work and I will update on what I find
Rado
US NAVY VETERAN
Maine
Pentastar 3.6 V6
Thank you
Kevinsull03
New York
Any update? I’m having the same issue. Yesterday I went to start the truck and nothing happened. I have had this happen a handful of times. The ignition switch has been replaced twice. After I wait awhile it starts.
If you don't have one of these,well worth picking one up,and then you can do your own battery load tests.That's where i'd start.
