2018 Towing Guide
Rampant
NJ
392 Hemi
Rampant
Rampant
NJ
392 Hemi
Deleted
SyN
6.7L CTD Owner
Tornado Alley
6.7L CTD
Many Thanks Ramp!
Added to my favorites
fljab
Mims, FL
Hey, thanks for that! I just posed a Q below about if my SCSB could tow 6K or so. Digital chart has no exact configuration for me, but like what I'm seeing and generally puts it to ~7K or so.
tron67j
Maryland
I put my truck in, and the numbers don't match to what I have for capacity other than gvwr, which of course is limited by regulation, and I also understand it is just a general set of values. One confusing point, why does vtwr increase by 600 pounds going from 3.73 to 4.00 ratio. That vtwr is a product of payload capacity and for a general set of numbers it should remain static, at least I would think so. Since the data you enter into that website returns results for a general truck in the category that you're choosing, I would think that because payload capacity is a product of the model and options that a truck has, it should just remain static because changing to a different gear ratio with all else remaining the same would not change your payload capacity, correct?
