2020 Ram 1500 Classic single exhaust size/options??
reklaw
Alabama
Looking to upgrade my exhaust to get a bit of a deeper sound, but I'm not sure of the inlet/outlet size for the muffler. I have the single exhaust. I assume it's 3inch and 3 inch but not 100% sure.
Also, will a flowmaster 40 series muffler give me a deeper sound but not too loud and aggressive? Thanks!
R
reklaw
Alabama
Look at Magnaflow.
Nice deep tone at WOT, but has excellent manners in town and drone is not bad at higher speeds.
Can I get just a muffler or what do I need? Sorry for the ignorant question.
CanuckRam1313
Ontario Canada
2023 Warlock SLT
Absolutely you can & happy to help!
However, a full cat-back system is designed with larger pipes and engineered to all work optimally. But they are more expensive than just a new performance muffler installation.
If you really want to open things up, look at having a custom y-pipe made up. This is a huge choke point for our HEMI trucks where the OEM smashes two 2.5" pipes into a single collector.
You'd need to source an experienced performance exhaust shop that specializes in custom exhaust work ;)
If you just want sound but not too obnoxious, look at a Magnaflow muffler.
R
reklaw
Alabama
Thanks a lot I really appreciate you!
Lsujker
Baton Rouge
That was for sound comparison. Was not a recommendation. An exhaust shop can install dang near anything you want.
Opinion, these trucks sound great as is. Longer trips would be exhausting if louder. Pun intended. Ha. Is there a sound difference between the duels vs singles?
Nick@GotExhaust
Preferred Vendor
SC
I do not recommend the Flowmaster 40 as it is a chambered exhaust. Chambered exhaust have been proven by a 3rd party to actually lose a little hp. Also the 40 series is aluminized steel which will rust out over time.
I like the MBRP catback for the single out, it sounds very deep and is very reasonably priced for a catback. There is no bolt in muffler kit for your truck so any muffler install will need to be fabbed in.
