2021 1500 Front & Rear Park Assist
fearroyo
Tampa, FL
EcoDiesel
Found a decent write up for adding the front and rear park assist module, sensors, and wiring. However, I am having a hard time narrowing down the correct module and front & rear harness for my 2021 1500 Big Horn. Does anyone know how to narrow down the correct module and front and rear wiring harness? Looking on BAM I am finding multiple parts with varying prices but don't know the difference for each or which is correct one to order. Below is the list for the 2021 1500 Ram under the Park Assist section on BAM. Any help would be greatly appreciated. @Jimmy07 @Mpgrimm2 any input would be greatly appreciated!
Parking Assist Module: $63.00 - 69.22
68464879AG - I think I have it narrowed down to this module
68464880AE
Front Wiring Harness: $33.10 - $66.42
68475598AA
68475599AA
68489200AA
68489201AA
68489202AA
68489203AA
68489204AA
68489205AA
68489206AA
68489207AA
68489208AA
68489209AA
68489210AA
68489211AA
68489212AA
68489213AA
68489214AA
Rear Fascia Wiring: $58.63 - $103.73
68475602AA
68475603AB
68475605AB
68475607AB
68475608AA
68488370AB
68488371AA
68488372AB
68488374AB
68488375AA
68488381AB
Mpgrimm2
Preferred Vendor
SC
2022 Ram 1500 (5th Gen)
5.7L
Reach out to @skuppy069 (ie message) and he can likely get you squared away as he has helped a few others
Rogerb
Miami
V8
fearroyo, were you able to add the front, back and the module to your ram 1500? I have a 2021 Ram 1500 Laramie, bought all the parts needed for the park assist and installed them, however the module (68464880AE) that goes by the drivers side cant find any harnesses or connectors there to be plugged in. Is there something else I need to get?
F
fearroyo
Tampa, FL
EcoDiesel
I decided not to add the parking sensors and started working on the 360 surround camera view.
Rogerb
Miami
V8
I’m almost done but have a question, the Can block in my truck is not the same color as yours, the connector can be plugged in into any of the vailable spaces as long as pin 1 goes to pin 6 and 2 to 12 or does it have to be a specific available port?
HarryS
Clovis NM
It needs to be in the correct can block, position doesn't matter
