U&A
- Apr 29, 2016
- 9,271
- 18,603
- Location
- Michigan
- 2016 3500 SRW
- 6.4 HEMI
Lots of good things have been said here but I just wanted to point out that in my opinion hitting the gas in making the truck down shift from 6th to 5th is not going “WOT”.
The dangerous type of “WOT” downshifts are from 6th to 4th.
I know this does not help you any now but when I am merging onto a highway instead of the truck deciding when to downshift I manually select The lower gear that I want the truck to be in before getting on the gas.
I also drive exclusively in tow haul mode until I NEED 6th.
With my 4.88 gears and 35” tires ill run in 5th on the highway around 63 mph at 2400 rpm for a while. That RPM will not hurt the trans or engine. 6th gear is super short in the 66rfe. Almost useless unless you have a minimum of 4.88’s.
If I was towing all the time at highway speed’s of around 65 to 70 I would get 5.13’s with my 35” tires....with no hesitation.
Again I know this is really not much help to you but I’m just stating my opinion.
