8 speed questions
Rlaman
Ohio
Does anybody know when I should change the trans fluid on my '19 2500 tradesmen with the 6.4? I tow a 6500lb camper thru Ohio hills. 28K miles on the clock so far. Dealer says it's lifetime oil. Not sure I agree with that.
Curmudgeon
York, Pennsylvania
2014 1500 Laramie 4x4 QC, True Blue Pearl
The manufacturer of the trans says 60,000 miles for heavy use and maybe 80,000 for "normal" use.
I had mine done at 92,000. No heavy use.
EDIT: Replace the pan and filter with every fluid change.
Administrator
PPE makes a heavy duty transmission pan for the 8 speeds,that holds another 2 quarts of fluid,and has a replacable filter.
R
Rlaman
Ohio
Thanks guys. I appreciate the info.
Aggie12
1997, now 2024
V-10, now 6.4l Hemi
Just crawled underneath my 2024 3500 6.4l to change the oil. And I noticed that the Transmission pan is plastic ! No protection for rocks or anything else, except for the transfer case skid plate further back. When did this madness start? I can just see a goodsized-rock getting kicked up and taking a bad bounce.
Thanks for the tip on the metal replacement cover, but it looks like they don't cover my year/model, only 2500's. Anybody have a quick reference while I keep looking? And: Any known problems with the plastic pan????
joesstripclub
Lees Summit, MO
2021 2500 PW
All the 8 speeds have had a plastic pan, except for some jeep application that I dont think they make anymore. I've seen a couple people doing some serious off roading that got a tree branch jammed into the pan, but otherwise not many issues. I would assume all the 8 speeds are the same in the 2500s and 3500s but I would defer to someone else more knowledgeable.
