8 speed swap
1SLwLS1
Just to further clarify the neutral cable for anyone else that may stumble upon this thread. If you're not going to use a cable and just rely on a screwdriver or pry bar for activating neutral, make sure you have some heavy duty zip ties as the lever does not stay in neutral once put into neutral, it springs back to park. You would need to activate neutral, tighten the zip ties and then you can keep the pre-sized/tightened zip tie setup and lever of choice in your vehicle, should you ever need it.
Trick for making braided lines,pull the zipties as tight as you can,then use a thin cut-off disc in an angle grinder to cut the hose between the zipties.
