91 Ram D250 5.9l Transmission cooler replacement options?
Ricin
United States
5.9 Cummins
My top mounted transmission cooler sprung a leak. I can not find an exact replacement with the cut out for the hood latch or even a cooler that has the line connections on the left rear to fit through the cut out on the left. Has anybody ran into this same issue? If so what tranny cooler did you use as a replacement?
I have to get this truck back on the road asap so I can get back to work. Any advice would be greatly appreciated. Thank you
IMG_20220515_185141.jpgIMG_20220515_160139.jpgIMG_20220515_160109.jpg9q
