'98 360 Not idling when warm.
dsgsr
Monroe, Me.
Hey folks, I'm new here I would appreciate any help you could give me. I Have a '98 plow truck, Idles fine for the first 20 mins of use. Then it won't idle when i let of the accelerator to shift gear. Any ideas? Is it something an old fart with little mechanic ability can fix. Don't have much money:(
Thank you,
David
OC455
Central NY
MAybe have the throttle body cleaned, check the connections for the idle air control valve, clean the idle air control valve. Get some throttle body/carb cleaner and cleaner for the electrical components/sensors. CRC makes spray cleaners for all of this.
Dean2
Near Edmonton
Throw a couple off cans of fuel system cleaner in the gas tank as well. When cold the truck runs at higher RPM and has a fuel enrichment circuit. When it gets hot, that circuit is not in play, and the idle RPM drops. Failure to idle hot is usually a fuel issue, rarely electrical, however when was the last time you changed the plugs. When did this failure to idle start and did you make any changes just before that.
