Adding Laramie Door panels
HarryS
Clovis NM
For those that have added Laramie door panels, how does the wiring for the courtesy lights connect? I know on the front doors they connect to the door module, but all I have is the pigtails for the two lights. (I don't have a junk yard nearby that can carry the newer model trucks.
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
LKQ used auto parts
they are nation wide
H
HarryS
Clovis NM
Yes, I'm aware that LKQ sells parts. I purchased the door panels from them. I'm asking what is needed to connect the door panel wiring (for the lights).
H
HarryS
Clovis NM
Thanks for all the help guys. I figured it out myself. Pigtailed the LED wires, connected them to each other, and then added a wire from the connector at the body, put a 2 wire connector between the two.
