AlfaOBD programmed a replacement Key fob ok but it stopped working
Sens East
Waterloo, Ontario
Hey Folks, Newbie here so apologies if this has been covered somewhere else but i didnt see the exact situation.
I have a 2013 Ram 1500 Hemi. Key fobs started working a little erratically (mostly the remote start would only work now and then) so I purchased a new fob from a "reputable" seller on Amazon. I already had AlfaOBD so was good to go. I followed the instructions to program and it worked perfectly. As soon I was done programming, the new fob locked unlocked and remote started the truck. I went inside happy things worked as planned.
Later I went to go out for a meeting so remote started with the new fob, went out to the truck and it unlocked when I put my hand on the door handle. I got in and off I went to my meeting. When I got there, as I walked away the fob would not lock the truck, would not unlock nor remote start. When I went to press the start button with the end of the fob the screen showed wrong key fob (or something like that). After ubering home and back to get my original fob, it unlocked and started fine.
Back at home I tried to re-program the new fob and it showed that it was already programmed. Thinking It was crap keyfob I ordered another, went through the same process (Connected to the RF Hub, read the PIN, selected program Highline FOBIK, pressed the unlock button once) and the key programmed up as expected, but once I wnet inside and tried to use it again in seems bricked like the first one.
Has anyone experienced this or have experience to know what I'm doing wrong? This is getting frustrating.
Thanks in advance, this forum is such a great wealth of knowledge!
Bobf
NJ
I have had the same thing happen, two different key fobs I programmed with alpha obd stopped working. I'm baffled too. It hasn't happened with the factory remotes.
Sens East
Sens East
Waterloo, Ontario
Are we just getting crappy remotes that won’t hold the program? I was lucky and the provider sent another one but I’m gun shy to try again and brick another one without knowing if I’m missing something here.
Chris B Iowa
United States
Yes
I just purchased 2 new fobs from Amazon and programmed with Alfaobd For my 2013 RAM 1500. The fobs worked great locking/unlocking and remote starting multiple times. The next morning, I drove the truck with one of my Fobs and shut off the engine and the fob failed When I tried a restart. Thinking I might have a bad unit, I retrieved my other fob and it worked perfectly once again until I shut the truck down. Another dead fob.
Bad fobs? Seems doubtful? I attempted to reprogram and as I suspected, they didn’t take the programming at all.
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
Usually, the OEM Fobiks did not go bad
If the FOBIK case was opened up
remove the battery
Look closely at the Green printed circuit board
Clean everything on the circuit board
Look very closely at the battery holder & any pressure points
There are 2 pressure springs that can be lifted just a bit
Then place a battery back into position
Now the outer case is another matter, the OEM case was ill designed.
on the back side of the cases buttons, there are contact points that tend to fall off, they can be cleaned, if they are still in place
If you ordered another FOB online
Use the non OEM case on your original FOB
you would be surprised how often that will work
RamDiver
Marlborough, Ontario, Canada
Just a thought for you folks with FOBs that worked fine and then later failed, have you tested the batteries with a multimeter or tried installing a new Duracell or similar battery in the FOB?
I've bought many devices over the years and in recent times, regardless of the quality of the device, suppliers use completely crap cheap a$$ batteries.
This could explain how they programmed correctly and then functioned for only a short period of time.
Chris B Iowa
United States
Yes
I checked the batteries before programming the Fobs and they tested good. Each Fob failed after using it to start the vehicle and then shutting it off. They both worked fine locking, unlocking and remote starting repeatedly before I drove the vehicle two successive times, one with each fob.
Either the fobs are no good, or the "registration" of the fobs within the system was lost in a reset of the computer when the vehicle was driven. I believe the latter is true. Is there another step that needs to happen? Resetting the system before driving?
Chris B Iowa
United States
Yes
The following link to You Tube is a video which shows how to program fobs for a Ram 1500 using the exact steps I used. He did not report having lost the fobs after a single use as many of us did.
A follow-up video shows how he used the Alfaobd with the obd mx+ to program his "remote start function" mentions that he was told to "drive the vehicle" to get the new settings to stick. He was skeptical, but followed the instructions and his remote start began working.
RamDiver
Have you tested the batteries since they failed to operate? More specifically, press numerous buttons repeatedly to create a load on the battery and then test it. The problem with cheap batteries is they may test out fine until you've applied a load for any period, then they fail. This is very common from my experience.
Unless, you say the battery is a quality name-brand such as Duracell, then they're usually safe to assume as functional after one test.
The way I interpret the above is that the FOB worked correctly when you at the beginning. The battery was fresh until it experienced a load. You state that every function appeared to work suggesting that the programming was successful.
When troubleshooting weird & wonderful faults, more often than not, the solution is typically a more simple problem even if we want to believe that it is astronomically complex.
This is why in basic troubleshooting when attacking an unknown fault, we try to rule out the most simple elements first. I can't guarantee that the batteries are to blame just like you can't guarantee they're not.
Testing batteries is painfully simple, why not start there and test them after creating a load?
If you care to search this site for crazy, bizarre, & weird electrical faults on Ram trucks, you will find a huge amount of them finally get traced back to a faulty starting battery. :cool:
Chris B Iowa
United States
Yes
UPDATE:
I checked the fobs in Alfaobd diagnostics and it reported the 2 new fobs were present in the memory, but were outside “parameters”. Alfa Obd tech rep advised that I needed to try a different source for the fobs and try again. I returned the first 2 fobs and purchased From a different source (also on Amazon). They are working perfectly…….so far.
Chris B Iowa
United States
Yes
Try a different source for your fobs. I had two do exactly the same thing using the exact procedure as you. The Alfaobd showed the 2 additional fobs having been programmed, but they were outside “parameters”. Alfaobd tech rep told me Probably the fobs were bad. I purchased a pair of new fobs also on Amazon and they programmed and are working fine. See below for vendor and price(2 fobs).
https://www.amazon.com/dp/B0859K5V64?psc=1&ref=ppx_yo2ov_dt_b_product_details#
$62.95
Sold by
USAREMOTE
Returns
Eligible for Return, Refund or Replacement within 30 days of receiipt.
2 Key fits Ram 2013 2014 2015 2016 2017 2018 Smart Keyless Entry Remote Fob (GQ4-54T)
JerryNed
Netherlands
HEMI 5.7
OK fingers crossed then, I purchased my fobs from Amazon as well. They look decent, but will post my findings shortly. Thnx.
GTyankee
3.0 ecodiesel
do not toss the old FOBs green printed circuit board
chances are that if you clean the circuit boards contact points with rubbing alcohol & then put the circuit board in the new FOB cases & give it a try
ramman95
Blackwood, NJ
2015 Ram 1500 Limited Crew Cab 6'4" Bed
5.7L Hemi 4X4
Key fobs are one of the things that I will always buy genuine OEM. You can usually find them new on ebay for around half of what the dealer would charge.
posttal
Cleveland , Ohio
2011 and 2013 Laramie
Glad to see i'm not the only one with this issue..well not glad but at least i'm not alone. I purchased a FOB for my 2013 laramie and programed it with the ALFAOBD and like others it locked,unlocked and remote started the truck....then i drove down to the park with the dog and the fob was dead when i tried to lock the truck..It wouldn't lock,unlock or anything...i had the alfaobd with me and tried t reprogram it but it said programing failed and that it was already programed.I ened up having the wife bring my original fob which is on the way out after going thru the washing machine but was still able to get me home... Taking the battery out of the FOB did nothing and lets face it why would it you dont loose programing when you change a battery...i even unhooked the trucks battery for a minute to reset the actual truck...still nothing. I had the company send me another FOB...and the SAME thing happened....so does anyone have a clue as to why this is happening ? ? It cant be the FOB since we are all having issues from different suppliers and bought at different times....PS my profile says 2011 ram but that truck got hit,rolled and totaled as shown in the picture and now i have the 2013.
posttal
Cleveland , Ohio
Any updates to this issue...after trying to amazon fobs and having this exact problem...that being the fobs worked perfect in the driveway and locked, unlocked,remote started and regular started the fob went dead after driving and then shutting off the truck. So i purchased a factory OEM fob....AND THE SAME THING HAPPENED ! I'm at a total loss as to why....and when i try and reprogram it i get this message.....................
zrock
canada
i ran into this with factory fobs. They are very random of when they work been like this when i got the truck. 1 is new OEM and one is original and they do the same things. I originally thought it was battery's as they always work for a day afterwards and then back to erratic. Remote start i gave up on that feature, door locks some days they work great and other days not so much. Pulled the fobs apart and cannot see anything wrong with the board, i don't think its anything on the truck side since i can replace the battery and they will work perfect. for a day or 2
posttal
Cleveland , Ohio
To those having this issue...what interface are you using for the AlfaOBD . .I'm using the VeePeak and an android phone..
18CrewDually
U.S.- New Jersey
Cummins 6.7 H.O.
Post 11 said the cheap replacement fobs was the problem. The poster listed ones known to work.
ffx2018
CA
Well my cheap amazon fobs died at 40 days. One completely and the other apparently intermittently. I see other people on the product page saying "broke after six months" but they left 5 stars on the review. That doesn't help anyone... I'm gonna call my old body shop and ask them to get a quote for wholesale price on a factory fob.
I used the OBDLink MX+ to program mine.
