AlphaOBD Pixel 7 Pro cannot connect via Bluetooth
tron67j
Maryland
Hoping for some assistance, it has been a couple years since I last used my alpha OBD unit to make any changes in my 2018 2500. The security bypass is still installed with the wires attached into the proper locations as it worked a few years back and all seems tight. I plugged the unit back in and can see the green power light on and the blue Bluetooth light blinking , but my phone will not pair up. I have tried two different Android phones and neither of them works. I took all other Bluetooth devices off of one of them just to see if that would make a difference but it doesn't. Does anyone have any ideas?
Black-Wolf
North Carolina
You don't say what OBD port scanner you have. Assuming you have an OBD MX+, have you followed the procedure for the OBD MX+ to pair it to your phone? You have to pair it first. Once it's paired, you can then connect using Alpha.
tron67j
tron67j
Maryland
Yes, OBD MX+. When I search in the list of Bluetooth devices that are discoverable nothing shows. I also have tried from the AlphaOBD app as well, and only ends up trying to control my unrelated wireless speaker. The Bluetooth light on the MX+ dongle blinks, but isn't available.
SitKneelBend
St. Louis
3.6 Pentastar
Took everything apart and reinstalled 3 times, and that was the charm. Now connected. Thanks!
Just FYI, when I had an issue with my OBDLink I contacted the company and they sent me an OBDLink MX+ at no charge (pretty sure I was out of warranty to).
tron67j
tron67j
Maryland
Yeah I have no idea what was going on but it was really frustrating. I had clicked on the pairing button and it wouldn't work. Guess it just needed to cycle a couple times or the wires. Just didn't feel like working. I have no idea but seems to be working okay now. Thanks everybody.
SitKneelBend
St. Louis
3.6 Pentastar
That was the issue with mine and when I opened it up the pairing button itself had physically broken.
tron67j
tron67j
Maryland
It might have been the button as well here, just not sure but so nutty.
