Are All Three Bulbs the Same??
Jack W
2005 Ram 1500. Are The tail lights, brake lights and back-up lights all the same bulbs #3057??
Runaround
Silsbee
You could also look it up on OReilly website but I’m certain the brake light bulb would be different because it would have to filaments in it and the tail and license plate light would have only one.
tron67j
Maryland
My 2003 had 3 bulbs, all 3057. One each for brake, twilight, and reverse light. Pretty easy to replace, a couple torx screws to remove assembly and then 4 Phillips screws to remove bulb holder from tailight assembly.
Daw14
Brake light bulbs are brighter then the others, yes thy are different.
Smokeybear01
US-NW Coast
Cummins 5.9
You can use all 3057 but there is an option for a brighter bulb for the brake. No dual filament needed in my 05.
