Auto Park disabled alert/ dash flashing off/on
JackJames47
Boston
2018 Bighorn 1500 5.7
while driving the dash flashes off all gauges and lights. Alert stating “auto park disabled”
G-Ride990
Administrator
Administrator
Chandler, AZ
Was the brake work related to the collision repair? Have you driven the truck since the work was done by the body shop?
Welcome to Ramforum too!
Rlaf75
East Hartford CT
If the sensors on the bumper of my 21 ram get dirty or covered by ice and snow the dash will flash randomly until I wipe them off. Maybe try cleaning them and see what happens. If it's still happening then and because it's apparently had some major work done to it take it back and let them check it over
J
JackJames47
Boston
The brake work was done after the repair. It was not a collision with another vehilce. I hit an object on the road and the damage was minimal, including only the front bumper and fog light. I have been driving the truck since last Friday. This morning was the first event with this alarm.
Thank you for the welcome and response.
RabidRam19
Saint Charles, MO
So my 2019 is doing something similar. The headlights flicker, the gauges all go to zero, either "Autopark Disabled" warning will show or sometimes " Check Electronic Braking System". It will occasionally reset the entire electronic system defaulting all settings for awhile then they return all on there own. Seems to be somewhat related to quick acceleration, however if it occurs at low speeds it will kill the engine and come to a clicking stop. Turn key too off then able to restart and go from there. I've been trying to catch an example of the whole ordeal on video but no luck so far. Any ideas
04fxdwgi
Coastal NE North Carolina
2016 1500 Sport
That sounds like an electrical connection / crappy plug connection / ground problem. Wiggle all connections while running and see if any thing changes.
1996smith
MS
Did any of get a solution on the auto park disabled and light flashing and truck shutting down?
beardedfarmer
Ontario
beardedfarmer
Ontario
Did you manage to figure out what was causing this? My 2019 just started doing this however I can't restart it .
