B&M transmission pan for the 8HP70 and 8HP75
W
My Mag-Hytec trans pan came with a corck gasket. never leaked in 5 years it was on.
But the factory o-ring gasket is a far better way to seal a pan Ian.No new manufacture'r uses a cork gasket anymore,so i'm not sure why Holley decided to not mill the groove required to re-use the factory o-ring,if PPE can mill the groove and they're a relatively small company compared to the Holley empire,i'm pretty sure Holley could of milled a groove to
W
Some rich guy needs to buy both pans and give us a comparision between the 2 pans.
Not me unfortunately,i ain't rich enough to do that test,lol.
I'm kind of waiting to see what John/Boosted Motosports thinks of it,as it looks like he's one of the first ones to have the B&M pan
W
looks to deep for off-roading and my skid plates
Yea i'm not so sure if it'd be an ideal pan out in the bushes,as it looks like it hangs down to the level of the transmission crossmember.I think you'd definitely want a skid plate under it,if you are hard core 4X4'ing.If it came down to it,you could space the skid plate down with washers or a spacer of some sort
caulk04
I just wanted a stock capacity pan anyway but PPE wouldn't confirm that any of their other pans would fit.
W
Jesse Hell Raiser has a stock depth pan,but i haven't been able to track much info down on it.
caulk04
It's no matter now, I just bought the one they said would fit at +2qt. Not a big deal, I just didn't see the need for extra capacity.
Really do need to order an extra filter though, I hate the idea that they could go belly up and we have no source for filters.
Frankwhoa
LA
Why is the filter part of the pan anyway? Can't someone make it separate?
Shawn Burns
Lewisburg, PA
2016 Rebel
The PPE and B&M pan have a replaceable filter,and i think some of the cheaper aftermarket composite pans have a replaceable filter
Did I miss something on the holley page? Where would you get a replacement filter for that B&M pan?
PaleFlyer
Charlotte NC
I'm guessing you've never experienced the thickness of the factory ZF fluid,water is damn near thicker then the factory fluid.I highly doubt there'd be a measurable differance in the milege by dropping the fluid temperature 5 to 10 degrees.But there's probably a measurable differance in the life of the transmission. Point being the HD trucks with the 8 speed hardly ever get over 170F while towing 7,000+lbs,they seem to run more in the 165 to 168 range,while the 1500's will run on average 20 degrees hotter,so their must be a reason the HD's run cooler,and i'm guessing it has more to do with keeping the 8 speed alive. I know the PPE pan pulled close to 5 degrees out of my 8 speeds operating temp,so i would think this pan would do the same or more,and i couldn't see any change in the trucks milege,in fact i can't even see any measurable change in milege on a 500 mile trip,with the transmission running at 140 which is where it runs at now. Maybe over a 100,000 miles you might see a bit of milege differance,but i even wonder about that.On a cool day (30 to 40F) and a easy drive,my wifes 6.4/8 speed Challenger will take well over 70 miles to even crest 120F on transmission temp,and i can still pull down 31/32mpg with it,basically the same milege it'll get with the transmission at 170 to 180F. If you do any towing i think this pan or the PPE pan are good investments,just for the fact you have more fluid volumne to absorb contaminents and heat spikes. You should buy this pan and report back on whether you see a milege drop,as right now this is all speculation,and you could be the one to try out your speculations
Well crap! My 8 speed must be bad then! It usually hits ~190 around the same time as the oil. Maybe a little slower. But over my 30ish mile commute to work during rush hour on the "highway", all 3 fluids hit around 200. Running empty on my 5.7
W
That's about normal on the 1500's,as they use coolant to heat the transmission fluid,the HD trucks and cars with the 8 speeds don't pre-heat the transmission fluid with coolant.The only ones heating the 8 speeds transmission fluid are the 1500's.
PaleFlyer
Charlotte NC
That would explain it! It did seem odd that the tranny got warm so much faster than the oil.
crazykid1994
Shawn Burns
Lewisburg, PA
2016 Rebel
Here's a reply from holley after I inquired about purchasing replacement filters.
Hello Shawn,
We offer replacement filters that would allow you to get a replacement filter when you need one. This is not something that should be hard to get, most of our dealers should have or have no issues getting a replacement filter.
Thanks,
Matthew Richmond
Customer Communications Specialist
1-866-464-6553 |
I still don't see any available for purchase on their website. There is a part number listed in the instructions manual. I don't think the gasket material choice and the unclear source for filter replacements are worth saving $20 over a PPE.
I'm having my crossover and factory connector pipe rerouted next week. After that, I think I'm going with the PPE to prepare for my next fluid change.
