Bank 2 Sensor 1 o2 Sensor replacement
jbmmurph
Georgia
I HAVE A BAD BANK 2 SENSOR 1 ON MY 2014 RAM 1500. I CANT SEEM TO LOCATE THE WIRING HARNESS. I CAN GET ACCESS TO THE SENSOR ON THE CADILITIC CONVERTER THROUGH THE PASSENGER SIDE FRONT WHEEL WELL, BUT I CANT LOCATE THE HARNESS. HOW CAN I GET TO TGAT HARNESS?
If you can't get at it,remove the tire / remove wheel well liner / and airbox ,then you can get at it's connector up behind the engine. If you're a bigger guy,that usually allows you enough room to crawl in and get to the connector
