Belltech 2/4 with IHC No Cut Kit Bottoming Out
Brody57
Oklahoma
2014 RCSB
I’ve got a 2014 RAM RCSB that I just put a Belltech 2/4 kit with Street Performance shocks on. I also have the IHC no cut kit with Hellwig rear sway bar and Spohn adjustable pan hard bar. I’m having an issue with my truck bottoming out on the bump stops. Anyone else had this issue or know how to fix it?
Bigskyroadglide
Montana, except for work
Hemi 5.7, supercharged
On my 14 RCSB, I Cut the bump stops off and installed air bags in the rear springs
Not either do both.
My truck no longer bottoms out. And I have about 4 to 5 inches of travel in the rear.
I also cut the front bump stops off..
You will need to install belltech bump stops. I used part #4923 front and rear.
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
My 2011 had the BT 2/4, removed stops.
