Bilstein at Got Exhaust
Nick@GotExhaust
Preferred Vendor
SC
Bilstein has been a popular name amongst RAM owners due to their many quality options. With Bilstein you can simply level your RAM with 5100's ou\r take it several steps further with 6112's, or even further with 8112's!
5100's
Bilstein B8 5100 (Ride Height Adjustable) shock absorbers are designed for trucks and SUVs with a front OE coilover style suspension. Multiple snap-ring grooves in the body allow for different spring seat positions, providing 0-3 inches of front lift with OE springs (depending on application). The monotube shock absorbers feature a 46mm digressive piston a with self-adjusting deflective disc valve setting. Bilstein B8 5100 (Ride Height Adjustable) shock absorbers provide increased wheel travel and improved handling. Utilizing a B8 5100 (Ride Height Adjustable) shock absorber is the easiest way to level out your vehicle.
6112's
Bilstein B8 6112 leveling kits are designed to provide more ground clearance, allow for larger tires, and increase wheel travel. Multiple snap-ring grooves in the body allow for different spring seat positions, providing 0-2.75 inches of front lift (depending on application). These kits consist of (2) 60mm shock absorbers combined with (2) custom matched cold wound coil springs and (2) billet aluminum spring seats. The large 60mm digressive piston allows for increased damping control for optimal on-road and off-road capabilities. Experience the legendary Bilstein off-road experience with the best direct fit spring and shock kit for your light truck or SUV.
8112's
Bilstein B8 8112 (ZoneControl) CR suspension kits are a direct fit, position sensitive coilover designed for light trucks and SUV’s. ZoneControl CR is a revolutionary technology delivering position sensitive damping. The system incorporates a triple piston design, offering 3 stages of compression valving and 2 stages of rebound valving. The coilover module utilizes a threaded spring seat for ride height adjustability ranging from 0-3.8” (depending on application). The coilover is supplied with a remote reservoir for increased cooling and an accompanied, bolt-on anodized reservoir chassis mount. BILSTEIN B8 8112 (ZoneControl) CR position sensitive coilovers will offer unparalleled ride comfort during every day driving combined with maximum control over large suspension inputs.
B12 rear springs, add 1"
Bilstein B12 (Special) suspension kits are designed to alter the vehicles ride height for optimum performance. Utilizing various different technologies to achieve the optimum ride height for a specific requirement. Bilstein B12 (Special) suspension kits provide the perfect combination of suspension dynamics, quality and aesthetics.
Rear 5100's
Bilstein B8 5100 shock absorbers are designed as a direct fit solution for lifted trucks and SUV’s. These shock absorbers feature a monotube design which provides consistent fade free performance. B8 5100 shock absorbers utilize a unique, velocity sensitive, digressive piston which reacts to changing road conditions. All B8 5100 shock absorbers are tuned for each specific application to assure optimal performance is achieved. B8 5100 shock absorbers offer a significant improvement in ride quality, handling, and comfort.
5160 Rear shocks
Bilstein B8 5160 remote reservoir shock absorbers are designed as a direct fit solution for lifted trucks and SUVs. The remote reservoir will offer increased cooling capacity and wheel travel to optimize overall performance compared to a traditional shock absorber. These shock absorbers feature a monotube design for consistent fade free performance and utilize velocity sensitive digressive valve settings which are tuned for each specific application. Each shock absorber is fitted with a unique 360 degree swivel banjo hose fitting and an attractive billet reservoir mount where applicable providing a clean, low profile installation. B8 5160 remote reservoir shock absorbers will increase overall durability of your vehicle allowing you to conquer the harshest of off-road environments.
8100 Rear shocks
Bilstein B8 8100 (Bypass) is a direct fit, position sensitive, damper for light trucks and SUV’s. These motorsports inspired shock absorbers utilize a dual tube externally adjustable bypass design. B8 8100 (Bypass) feature “Incremental Flow” bypass adjusters, allowing for finite and incremental changes for rebound and compression. The shocks utilize a bottom hose, remote reservoir exit port, delivering increased compression control during the full cycle. The remote reservoir is supplied with a bolt-on aluminum anodized chassis mount for an easy fitment. BILSTEIN B8 8100 (Bypass) will maximize the driver experience, offering unparalleled ride comfort and incredible bottom out control.
Message me for info and and pricing
Nick@GotExhaust
Nick@GotExhaust
Preferred Vendor
SC
Message me for info and pricing
Nick@GotExhaust
Nick@GotExhaust
Preferred Vendor
SC
We got options for Bilstein from level kits to full shock and coil packages
JamesCrowe
Canada
Is this just for 5th gen?
When I used 4th gen/classic this doesn't come up, just Fox 2.0 fronts a d Zone UCAs
Highway
Ky
Using 5100’s to level on highest setting do you need to change uca’s or have alignment Done ?
Nick@GotExhaust
Nick@GotExhaust
Preferred Vendor
SC
We do not have everything listed on our site. If you would like a quote message me please
Nick@GotExhaust
Nick@GotExhaust
Preferred Vendor
SC
At highest setting yes, anytime you go over 2" you want to upgrade to angle correcting UCA's
Anytime you make a change to suspension height you need an alignment. Doesnt matter if you lift it 1" or 2.8"
Nick@GotExhaust
Nick@GotExhaust
Preferred Vendor
SC
Contact us for info whether you are just looking to level your RAM or if you want a full suspension setup
Nick@GotExhaust
Nick@GotExhaust
Preferred Vendor
SC
One of the more popular suspension brands for the RAM right here at Got Exhaust
Nick@GotExhaust
Nick@GotExhaust
Preferred Vendor
SC
We can assist with picking out the best combo of parts to fit your needs and budget
quickster2
SE Michigan
2015 Ram Laramie 2500 4 X 4
6.4L
Shout out to Nick. New Bilstein's at the 4 corners (4600's) as well as the rear axle damper (5100). Also Fox 2.0 steering stabilizer. 6 pieces very fast shipping at a great price! I wanted to maintain stock ride height can't wait to get the goods installed.
Nick@GotExhaust
Nick@GotExhaust
Preferred Vendor
SC
Thank you!!
Nick@GotExhaust
Nick@GotExhaust
Preferred Vendor
SC
Contact us for pricing, whether you are just looking to level or improve your off road performance
quickster2
SE Michigan
6.4L
Had the 6 pieces installed. Along with new front sway bay bushings truck drives better than new. Previously I installed a Hellwig rear sway bar and end links. Great combination Nick spec'd out. Very satisfied.
Nick@GotExhaust
Nick@GotExhaust
Preferred Vendor
SC
Excellent experience with Nick myself, highly recommend to all forum users
Thank you both for the kind words! Happy to help!!
Nick@GotExhaust
Nick@GotExhaust
Preferred Vendor
SC
Great way to level your RAM and to increase on road ride comfort and off road performance.
Nick@GotExhaust
Nick@GotExhaust
Preferred Vendor
SC
Contact me for pricing and availability
