Blower Motor Mystery
iplax13
New York
3.6 V 6
I have a 2017 slt v6.
I have replaced the blower motor 2 times in the pat 2 years. It seems to start off fine, then slowly work inconsistently and then completely stop working. Looking or any potential solutions as it was -3 degrees today and I really missed my heat!
SitKneelBend
St. Louis
3.6 Pentastar
Is the cabin air filter present and if so has it been changed/cleaned consistently?
I
iplax13
New York
3.6 V 6
Thanks for the response. Filter wasn’t bad but replaced it. Replaced the fuse as well and put in another new blower motor. Still no luck.
1999 White C5 Coupe
I’m curious - did you use an OEM Ram blower motor assembly each time?
I
iplax13
New York
3.6 V 6
First one was oem from the dealership. The following 2 have been 4seasons from my mechanic. The dealer didn’t want to replace it for free after failure in 7 months so I politely told them to kick rocks.
SitKneelBend
St. Louis
3.6 Pentastar
I'd look at your service sheet, most Chrysler dealers have a two year warranty on OEM parts installed.
Rado
US NAVY VETERAN
Maine
Pentastar 3.6 V6
How hard was it to change blower motor ?
Thanks
I
iplax13
New York
3.6 V 6
Lots of work still no progress. Blower motor is good. I have no power at the fuse location. What would the next step be? I’ve swapped over the fuse with others to ensure that the fuse wasn’t the issue.
SitKneelBend
St. Louis
3.6 Pentastar
A fan resistor problem maybe?
I
iplax13
New York
3.6 V 6
Update. May have solved but time will tell. Replaced the relay and that seems to work for the time being. Will report back with updates.
