Brake lines question.
vtdodge
Newbury, VT
5.9L
I have a 1990 W350 that needs rear lines. I can't find anyone that sells prefabricated lines for a W350, yet I can for a W250. Are these the same or is there a difference between the lines on a W250 and a W350. This is a SRW truck.
u2slow
BC, Canada
Cummins 6BTA
The dually diffs are either ~2" or ~7" wider than srw. If its indeed a srw diff, should be the same as the dana 70 srw in a d/w250.
I would just bend up my own lines from bulk tubing.
V
vtdodge
Newbury, VT
5.9L
Thank you for the information. I will order the lines today.
cbassrex
