Calibrating Blend door actuators
Jmbhydraulics
Colorado
I own a 2016 Ram 3500 Tradesmen 6.4, the heater core was replaced and with the heater box out the blend door actuators were replaced. Full disclosure we attempted to get the timing of the position correct when we reassembled everything. Once back together we performed the door calibration with Alfa OBD. It showed all passed and everything worked good for about a half hour then the front heat/cold actuator stoped as well as the recirculate door as well. Performed calibration again and all but 1 failed. I am sure we did not install all of the actuators correctly but I can not find the procedure to install all 5 then calibrate correctly. If anyone know how please let me know. Any help would be appreciated.
Mister Luck
cassis tutissima virtus
WEST COAST
5.7 V8
I thought they recalibrate themselves as long as you align the door tabs to the hinge
hyder124
Ramsey MN
I am having the same issue. I replaced the heater core and thought, "I may as well change these while I'm in here so I don't have to do it again" Well now here I am reading through posts to find out how I can fix what I messed up. Does anyone know the position that it should be in? Is the "box" outline at the door supposed to line up with the keyed portion of the actuator post? Are the marks on the actuator supposed to line up with each other prior to installation?
