Codes 24 and 33
dev199505
Im getting codes 24 and 33 i know 24 is throttle position sensor could this be why my truck has a hard time starting? 33 is ac related which makes no sense my truck has no ac
Sent from my LG-K373 using Tapatalk
crazzywolfie
under the truck
code 33 is pretty normal for trucks without a/c. have you tried erasing the code to see if it comes back. it is possible that the throttle position sensor might be causing issues.
D
dev199505
Yeah had the battery disconnected overnight now im only getting 12 and 33 i had unplugged the tps to see if it ran any different was trying to find out why it was having a hard time starting and unplugging it didnt effect it at all so back to searching
D
dev199505
Now its running like crap though super sluggish
crazzywolfie
under the truck
have you tried priming the fuel system before starting it? key on wait 5 seconds, key off, key back wait 5 seconds and then try starting? see if it makes a difference
D
dev199505
Ill try that
D
dev199505
Priming didnt help maybe throttle body just needs a rebuild, probably do a carb conversion with tax returns
crazzywolfie
under the truck
i personally would not do a carb conversion unless the truck is a toy that you only drive in the summer because the cost of all the parts needed to do the conversion are not really cheap by the time all is said and done. you would need a complete ignition system on top of new intake/carb and fuel pressure regulator.
have you replaced any sensors or parts on the engine? i would maybe wonder if it is a hall effects sensor.
D
dev199505
I havent replaced anything' ecu and wiring was all done recently still has sticker on ecu and the engine harness looks brand new, i know the truck sat for a while before i bought it, i wanna do a carb conversion cause of how gutless the thing is and i cant add a cam with out it, could the throttle body being overtightend cause issues, i did tighten it down because the bolts didnt seem that tight
crazzywolfie
under the truck
sitting shouldn't hurt anything as far as i can tell other than things like the fuel sending unit. ya you can't do much about the cam without changing thing up but i would possibly consider looking at some sort of aftermarket fuel injection setup like a Fi-Tech setup. they are are fairly cheap and pretty self tuning. they also have options like the option to control electric fans if you decide to ad some. it will cost a bit more than converting to carb but it would make the truck easier to use as a daily driver and would also likely give you more power than a carb would without having to really do all the trial and error tuning that you have to sometimes do when building an engine.
https://www.summitracing.com/int/parts/fif-30003/overview/
[yt]2sQJPZYSoUI[/yt]
i don't think over tightening TB bolts should effect it any. i would think you possibly have a sensor acting up or something not working right.
D
dev199505
Im gonna change out the filter first and see if that helps
crazzywolfie
under the truck
i don't know if a filter would make that much of a difference on a fuel injected vehicle. you could pull it and try blowing through it both ways. probably wouldn't hurt to replace it but i don't think it is what is causing your issue.
D
dev199505
Figured itd be the cheapest part so ill start there lol
crazzywolfie
under the truck
i would probably start by just blowing through it since that is free. them fuel injected fuel filters are not as cheap as you would think. i think they are usually about $20-30 which is why i haven't replaced one yet.
D
dev199505
Ive replaced it once but the truck sat for atleast a year with fuel in the tank
crazzywolfie
under the truck
if the filter is only 1 year old then i wouldn't even worry about it. it would take a lot longer than a year for stuff like the fuel to really break down and clog the system.
D
dev199505
Its working its self out driving now and its getting better, wonder of it was just cause the tps being unplugged for a little bit
crazzywolfie
under the truck
the computer could still just be re-learning since you reset the computer. is it still hard to start?
D
dev199505
If i prime it 3 times its fine, if it's loosing pressure should i start replacing fuel lines?
crazzywolfie
under the truck
hard to say. what shape are the fuel lines in? if they look decent and there is not any obvious leaks i would probably leave them. i think if you are loosing pressure and you don't have any fuel line leaks it can sometimes be the fuel pump or fuel pressure regulator. i forget which or if it could be both.
