DEF additive
BASSCATLILDAVE
Silverhill Al
I saw where there is a DEF additive. I had a customer ask for some the other day and I've never heard of it. I see Rislone 4780 is the part number.
BWL
Embrace the skeptisism
BC Canada
Hard to find because most people know it'll do more harm than good. If it does any good at all.
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
That site that i posted, reads that the water is just a carrier.
It evaporates when it sprays into the heat of the exhaust system.
Then the actual chemicals break down & do what they are designed to do
BossHogg
Oakland Township, Michigan
6.7L Cummins
I think there is a facet of people that are addicted to the word "additive". They, for whatever reason, just seem to need to use it. I'm not saying additives are bad but not always needed either. DEF is a very specific formula of deionized water and 32.5% Urea. Adding an additive would change the very precise DEF recipe.
zrock
canada
like said above snake oil... As a parts person you should know this, i would never recommend or even give the customer the idea i would look into it.
2003F350
6.7 CTD
I have a neighbor that just bought a baby Duramax. He has a 'friend' who keeps selling him 'home made DEF,' and he's offered it to me.
Since he's been using it, he's been getting a lot of CELs that all have to do with his exhaust/DEF system, and he keeps just having it shut off - at the dealership. He keeps turning down any work that they say they want to do.
Needless to say I've turned him down and won't put the stuff in my truck. I'll stick with Blue, thanks.
turkeybird56
Central Texas
Needing DEF one thing. Home made brew put into these PITA systems, now that is another thing, and an additive? Hmmmmmmmm. Well, each of us owns our trucks (---- finance company, lol), and that be a personal decision. Since I no longer have a diesel, not a decision that is associated to me.
chaosh1
I use the Blue platinum and would never add anything to it nor use a home made brew
2003F350
6.7 CTD
Yeah that was kinda my point - stick with a good DEF, and don't add an additive to it. I'd say it's okay to add Diesel Kleen or some other anti-gel additive to your fuel in the winter, Cetane Boost if you can't get good diesel, and Diesel 911 if you DO gel up...but otherwise there isn't much additive I'd add to a modern diesel fuel either.
GTyankee
3.0 ecodiesel
any DEF should be good as is, brand name should not matter
But ... i have heard more Cons than Pros, when it comes to BLUE DEF Platinum
MSDS only shows WATER & UREA
Maybe some users are confused between
DEF
DPF
chaosh1
DEF
DPF
I would be interested to hear the cons. its all i have been running and so far, no issues
06 Dodge
Forest Grove, Oregon
6.7L CTD
All DEF has to be 32.5% Urea, DEF is DEF, so don't understand why so many spend more buying one brand over another or even the so called Blue Platinum when cheap Walmart or Kroger brand does the same as Def Blue an it a lot cost less, you just need to be sure your not buying old stock by checking the manufactured date and never buy a box of Def stetting out in the sun at the fuel island like I see every summer as heat shortens is life...
GTyankee
3.0 ecodiesel
What are the ingredients in BlueDEF PLATINUM?
BlueDEF PLATINUM with advanced SYSTEM SHIELD technology is a mixture of high purity synthetic urea, deionized water and our proprietary additive package manufactured under ISO 22241 guidelines to ensure product quality.
MSDS shows nothing besides water & Urea
RV forum member wrote
Curious if anyone has been using the new Platinum DEF. Their marketing seems to make sense. However, I saw on a GM diesel forum that it is not recommended for Duramax System
another reply to above:
32-33% synthetic urea
67-68% distilled water
?? proprietary additive
Other than an additive to reduce deposits same ole DEF
Write Up on DEF issues in general, DEF causes deposits ......
so , maybe additives should be used ??
GTyankee
3.0 ecodiesel
On the other hand, one diesel owner stated that, if you do not think that the DEF Platinum works to eliminate the deposits.
You can see for yourself which CLEANS better, by looking at the DEF Injector, both before & after using regular DEF & DEF with Platinum
chaosh1
Its really not that much more $$, so for me if it makes a difference awesome, if it doesn't cool. we pay more for insurance and never need it. so platinum it is
06 Dodge
6.7L CTD
Where I'm at Wally Def is $9.98, Blue Platinum is $29.99 when not on sale & plain Blue Def. is $17.00, if I did not live a 50 minute drive from the Pilot truck stop would buy it at the pump, I know of hot shot owner who put almost 489K on one truck, 390K on another both used truck stop Def with no reported Def deposits.. If a person was really worried about deposit you could always use something like Rislone Def treatment that claims to get reduce deposits for $15.00 an still save a few $$
chaosh1
Yes, it's really not that much money..
