DIY: 2013-2017 RA3/RA4 8.4" Radio Upgrade/HVAC Conversion
Mpgrimm2
Mpgrimm2
Preferred Vendor
SC
2022 Ram 1500 (5th Gen)
5.7L
Does anyone know if the following HVAC Modules will work with a 2013 Ram with Factory 4Speed fan.
HVAC Modules - 68183973AB, and 68268186AA
No. Those are for 14-17 1500's with 7 Speed Fan/HVAC system
MDCounsel
Damascus, Md
I'll jump on the bandwagon and give Mpgrimm2 a big thumb's up! The guy is great and very helpful. I have a 2016 Tradesman and after upgrading my Wrangler's radio and also always seeing the radio in my wife's Traverse the RA2 has been annoying me. I bought a VP3 NA (from a scrapped 2015 Cherokee), HVAC bezel, and HVAC module from E-Bay and a wiring harness from Mpgrimm2. The install was surprisingly easy BUT the hard controls on the HVAC bezel weren't working. I reached out to Mpgrimm2 who suggested a bad bezel given everything else was working. He offered to repair the bezel but I bought another salvage bezel and all is working now.
When I first installed everything the radio showed a Jeep splash screen but started playing music even though my bezel controls were not working. It then went through a reset and showed a Ram splash screen. At that point it stopped playing music. My on screen controls all worked- I could change radio and Sirius stations, operate my climate controls from the screen, but no function or illumination on the HVAC bezel. I let Mpgrimm2 know and he said that given I could control the HVAC from the screen but not the bezel then the bezel must be bad. The new bezel fixed everything but I don't know if it is a truck year issue or an actual defective bezel.
Here are the part numbers I used:
Radio- VP3 NA: 683-04624
HVAC Module: 68366552AA, from a 2017 Ram and it works with no issues
HVAC Bezel: Defective one was 1UJ96DX9AC (2013 Ram) and the one that works is 1UJ96DX9AF (2014 Ram)
Thanks and good luck. I really do like the new radio.
bretthays
Indiana
So I just finished installing a UAQ and 7” cluster with 4thgenmods harness and added the HVAC module. I have the 7 speed fan.
Do you offer an add on harness so I could add the temp and humidity sensor to get ATC or would I have to completely replace the harness I just installed?
670hoth
Maine, USA
I want to add the MTC or single zone ATC bezel but the #68268186AA is now so expensive that it makes it not worth it. Is there another module or solution?
Mpgrimm2
Mpgrimm2
Preferred Vendor
SC
5.7L
Yes I can build an add-on harness set or I'd recommend you plan on replacing it with my 8.4 conversion setup with ATC. It's about $30 more to go with the full conversion harness atc setup vs universal add-on set
raceghost
Idaho
3.0L Eco Diesel
Does anyone have a good write up or pictures on the 40/20/40 Jump seat tear down. Gonna do a custom media hub, and possibly if it goes wrong, will order the 2018+ tray and get the 2018 Ram Hub. Just need pictures on how to get the tub out that the media hub clips into. Thanks in advance,
Update: Thanks M2Grimm, Mike I found your YouTube Video on it. Anyone else --> https://www.youtube.com/watch?v=tq44VqM9Ipw
Dezel2000
Ponchatoula, LA
Cummins 6.7
Wanted to give a huge shot out to Mike MPGRIMM2 and everyone else that went in to this. I bought my truck as a work truck long ago and plans changed and now it's uses for play and to get my family around. Was definitely missing out on all the extras on the interior my truck was a tradesman. Thinking about buying a new truck but did a lot of exterior work to mine and didn't wanna start over lol. After researching and finding a bunch of threads about upgrading my interior I looked into several places and spoke to several people After speaking to Mike I made up my mind thanks for taking to me like a person to person and not a salesperson. I been completely transforming my interior and couldn't be happier. I now have 8.4 bezel 4 to 7sp ac fog lights with factory switch trailer brakes and more to come. Thanks again. M2mods4ram.com.
sauce
Wisconsin
6.7 cummins
Converting a 2013+ (thru 2016) RA1/RA2 MTC bezel
with 4 speed blower
to a RA3/RA4 MTC bezel and Radio.
** POST 17 : Important note/Caution about using cheap cloned blower resistors **
It’s been quite a journey developing this harness along with Getupkid, Duneflyer, Mondo myself and several others. We now have a complete DIY solution for upgrading to the RA4 or RA3 from the RA1 and RA2 radios. The basic Radio is PNP now that we can use the 8.4 bezel and HVAC controls.
There are currently two factory setups for the hvac blower: the 7 speed and the 4 speed.
This is how I understand how the trucks were built, if they were equipped with the RA1 or RA2 radios.
2013 1500's have the 4 speed blower setup. (Fixed Displacement Compressor)
2013-2018 2500/3500's have the 4 speed blower set up. (Fixed Displacement Compressor)
2014-2018 1500's have the 7 speed blower set up (Var. Displacement Compressor)
NOTE:
The conversion for the 7 speed factory fan set up while similar is different and involves not only a different HVAC module but the pinouts for the conversion harness are also slightly different, see Post 2.
Parts Required For MOD:
01. 8.4 Uconnect Radio (VP3/RA3 - Non-Nav) or (VP4/RA4 - Nav)
** For Compatible RA4 Radios see here. **Check car-part.com, Schram, ebay, etc.
02. SINGLE ZONE OEM 8.4" (MTC) BEZEL: 1UJ96DX9AF (AC, AD, AE, etc)
** Optional: DUAL ZONE 8.4" (ATC) BEZEL, while not preferred, will work. See POST 15
03. Base to 8.4 Radio Conversion Harness (4 speed Fan specific):
. . See below to make your own in standard or extended length
. . (or get an extended one from: M² Mods )
04. HVAC CONTROL MODULE: 68105017Ax (AA, AB, etc) (4 to 7 speed Fan specific)
. . ** If you use the wrong module (ie xxxx8186Ax = no A/C, or xxxx8187Ax = No A/C & 6 vs 7 fan speeds)
< 10/4/19 edit > 2018 2500/3500's w/UAx = 68366553AA HVAC module. See post 89.
** UAx Radio Upgrade has very high likelyhood of HVAC Blend door issues that are fixed by adding the ATC wiring mod with conversion. See links in UAQ/UAS Upgrade thread. **
05. Fan Motor Power/Resistor Harness: 68048906AA (Req's Modification)
. . (or see DeereGuy's write-up of 00R/T's notes to make your own at roll-up posts 1765-1766 or get the plug-n-play version at M² Mods ... watch out for poorly made ones elsewhere)
06. 7spd Blower Resistor: 68048901AA (same as Denso PN 499300-2121) See ebay ad and Post 51 )
07. 911 Error Fix/Cell Bypass Plug: (or SharkFin Antenna mod)
. . See note 1 (below) to make your own or get one from M² Mods.
Mpg2's Instruction Sheet References:
- 2013-2017 8.4 Conv for 4 Speed Fan Trucks 7-6-17.pdf v1 <----- RECOMMENDED READING
- 2013-2016 Ram Radio Removal 6-27-16.pdf
- 2013-2016 Ram RearView Mirror (w/mics) Upgrade & Harness install 7-8-16.pdf
Optional parts
- PLEASE SEE POST 2
NOTE 1:
You can omit the Antenna body cable, Antenna jumper cable, and shark fin antenna if you get the Bypass Plug from M² Mods
Or you can make your own using the following parts (search ebay and amazon for these)
Farka D connector/Pigtail with 2 to 6 inch lead
10k Ohm Resistor with 5% tolerance, 1/2 watt.
Just solder one end of the resistor to the center wire and the other end to the wire shielding. Tape it up with electrical tape or heat shrink it.
Connectors & Pins to Make Conversion Harness
08. 24 Pin Connector 1: 1318917-1 TE Connectivity | Mouser
09. 24 Pin Connector 1 - (F) Sockets: 1123343-1 TE Connectivity / AMP | Mouser
10. 24 Pin Connector 2: 1376103-1 TE Connectivity | Mouser
11. 24 Pin Connector 2 - (M) Pins: 1376109-1 TE Connectivity / AMP | Mouser
12. 08 Pin Female - Connector: 30700-1081 Molex | Mouser
13. 08 Pin Female - (F) Sockets: 1393366-1 TE Connectivity / AMP | Mouser
Connector/Harness Reference:
- 8 Pin Center Stack HVAC Conn 0307001081 AS-30700-000 Series Instruction Sheet.pdf
- 24 Pin HVAC TEconn 025series Instruction Sheet 411-5928_G4.pdf
- Cptwing's harness making notes at Post 9
- Mpgrimm2 Harness Soldering Notes at Post 13
14. Wire 22 gauge 50.0 inches long QTY of 20
15. Wire 22 gauge 18.0 inches long QTY of 5
16. Electrical tape one roll should be enough
17. Wire ties
18. Heat Shrink
19. Solder/Soldering Iron
20. Split Wire loom or Nylon Braided Sleeving
Along with this you will need the following:
21. Wire strippers..
22. Crimpers double roll type recommend ratchet type
.... See post 12 for some notes on possible crimpers.
23. Heat gun
24. Small awl or similar tool to de pin connector
Here is a shot of everything needed except that some tools are not shown.
The diagram shown below details the conversion harness and pinouts of the various connectors, what is not shown and will be addressed later is how part 1 above ties into it, at pin 17 on the module side.
CptWing RA4 Conversion Harness layout - 4spd w/Mpg2 Edits 4-16-17.jpg
And after a bit of work and eye strain your harness should look something like this...
Just wanted to give a huge thank you to the guys who helped get my 8.4 conversion working! Everything went smoothly and everything made sense. I highly recommend this product if you plan on updating to the 8.4 radio. Wire harnesses were very high quality along with the modules i was sent. I will be purchasing the seat harness from these guys as well. 10/10
littlebiscuit
6.4l Hemi
Wanted to give a huge shot out to Mike MPGRIMM2 and everyone else that went in to this. After researching and finding a bunch of threads about upgrading my my 3.0 ra1 uconnect to 8.4 uconnect w nav I looked into several places and spoke to several people After speaking to Mike I made up my mind thanks. I own a 2018 ram 3500 6.4 L dually. For the life of me can't understand ram thinking putting backup camera in mirror on 3500 dually but they did with cheapest radio possible with no possible way to display on radio. So with help from Mike he helped me with all the cable builds required and shipped them pretty fast to upgrade my 3.0 radio with all plug and play cables. Also did the backup up camera from mirror to 8.4 radio display. This required a new single zone radio bezel, Radio, 4 to seven spd climate control module and resister. In which Mike helped me the hole way. All the links he provided were excellent. Mike Thanks Again!
UnaPachanga
MPGRIMM2 is the man! I too just upgraded my 2500 to the 8.4 and he was extremely timely with his response and shipping my needed parts to make it happen. If anyone is here is on the fence about doing it yourself, don’t be afraid! It really is not that difficult with all the legwork and support these fine folks have been providing.
cswift
NC
Big shoutout to MPGrimm2. I upgraded my tradesman 2500 to an RA4 with Single ATC. I had a fully manual mirror and used his guide for the mirror (harness pn for clearance lights, mirror pn). Mike made me the necessary harnesses and provided the appropriate bezel, with a 4 day turnaround time (with shipping). He knows his stuff and stands out for his knowledge base and customer service.
Thanks Mike!
DrewFire
Georgetown, ON
Hey, Mike. I was wondering if you could help me here. I may have screwed I may have not, we shall see!
I'm running a Canadian Ram Sport with the factory VP3 8" UConnect screen and it works great, I purchased a 2019 8.4" screen with carplay off of a friend and he included the media hub for his 2017. To my understanding I need the wiring for dual usb to work and to work the carplay/android auto feature.
I tied it all in to try and the radio/sat/bluetooth work perfectly. The backup camera doesn't :( and I don't think it will from now on. Unless you know of a fix.
Can you point me in the right direction to get the media hub working with the android auto. The original hub is the sd/usb/aux hub about 1.5" tall and 2.5" wide.
If needed I'll be buying the wiring off of you to get it all working properly.
Thanks for any help!
Mpgrimm2
Mpgrimm2
Preferred Vendor
SC
5.7L
I'm send you a message to get things started.
Style61
California
3.0 Ecodiesel
with 4 speed blower
NOTE:
04. HVAC CONTROL MODULE: 68105017Ax (AA, AB, etc) (4 to 7 speed Fan specific). Replaces 68186216Ax, 68236773Ax, 68268187Ax.
. . ** If you use the wrong/incompatible module (ie xxxx8186Ax = No A/C & 6 vs 7 fan speeds)
< 10/4/19 edit > 2018 2500/3500's w/UAx = 68366553Ax HVAC module. See post 89.
Optional parts
- PLEASE SEE POST 2
NOTE 1:
17. Wire ties
18. Heat Shrink
23. Heat gun
I hope you can help. I have a 2019 Ram 1500 Tradesman that came with the 5" blue tooth radio and I installed a RA4 #68270661AF with Nav. I also installed a harness from CarplayNav with control module P68105017AE
My original 7 speed fan now only goes up to 6 but some times goes up to 7 with no difference between 6 and 7 speed. Im also getting the 911 error even though I installed the 911 service disabler, Also my bezel is a dual zone with auto and I would like to enable the auto function.
Mpgrimm2
Mpgrimm2
Preferred Vendor
SC
5.7L
... And any word from the folks you bought the harness from? (I have dealt with them before, and I won't again)
Is this a 2019 4th gen classic 5 lug truck or newer 5th Gen with 6 lug
OutlawTrucker
Meansville GA
Cummins 6.7
I did the RA2-RA4 upgrade with Mike's harness. Stupid easy plug n play. Even kept my heated seats and wheel control in the radio screen. I no longer have those buttons on the dash because I installed the factory aux switches and with the RA4 radio I can have my heated seats and aux switches. Talk about having your cake and eating it too
Headlights are from retroshop. 2015 ram 2500 6.7
Style61
California
3.0 Ecodiesel
Yes, I spoke to them but they were not much help. Yes its a 2019 4th Gen 5 lug
reddawg67
Winder ,Ga
Hi , just completed the 8.4 upgrade with a 2017 ra3 non nav 225 hvac module used 145 8.4 bezel 150 with the atc buttonpractically new ! and the awsome wirring harness from @Mpgrimm2 and M2mods for 210 with the atc bulit in . grand total 730.oo alot cheaper than the 1400 bucks from infotainment peeps and works like a charm . Tanks again @Mpgrimm2 for the tech support . But the wife says i cant talk to you anymore lol to many mod ideas ! Also up dated the files from this post with no glitches and works flawlessly ! Thanks to all who keep this thread updated and put in the time working on these upgrades ! My 2017 ram 1500 express 5.7 hemi is coming around slowly . atc upgrade is next then heated and cooled leather seats if its affordable lol .... shhh dont tell the wife (wink)
Mpgrimm2
Mpgrimm2
Preferred Vendor
SC
5.7L
I hope you can help. I have a 2019 Ram 1500 classic Tradesman that came with the 5" blue tooth radio and I installed a RA4 #68270661AF with Nav. I also installed a harness from CarplayNav with control module P68105017AE
I've got another CarPlayNav customer reaching out with issues ...
JKeeling1020
Holly springs Mississippi
I have a Ra2 system and bezel going in a 2015 that has cut harness it was a ra3 system b4 it was stolen I need a giagram for the 24 pin ra2 &the 8 pin ra3 HVAC can someone please help I've looked high and low an still no luck
