DIY brake conversion
bobwest
slant 6
I recently bought an 86 d100 and want to convert the drum brakes to disc brakes. Has anyone ever done it?
crazzywolfie
under the truck
yup. they have conversion kits available for pretty much any dodge axle available. you just need to figure out what axle you have
B
bobwest
slant 6
Thanks for the input. I'm really looking forward to doing the project
Pedal2metal
Myrtle Beach
It’s been 5 years since you posted this regarding rear disc conversion. How did it go? Where did you find a kit? I recently bought a 86 D100 and want to do the same
reek
Sacramento
2015 RAM 2500 CC 4x4, 72 D100, 73 D100, 01 RAM 2500 field truck
like Crazzywolfie said, circa 2015, figure out which axle you have and find a kit for the axle.
my 92 9.25 rear end drum backing plates were identical to my 72 8.75 rear end. I used a 1969 dodge charger rear disc conversion on my 72 rear end. so that should theoretically fit a 92. but you have to figure out which rear end you have and work backwards from there.
