ECO mode. 5.7 engine
Captrv
Arkansaw
Can the ECO Mode be be disabled or turned off permanently on a 2021 1500 ram w/ 5.7 engine.
Wanted33
Down South in Dixie
5.7L
Yes sir, but you'll have to do it everytime you start the engine. Just push the "minus" (-) button on the gear selector on the right side of the steering wheel. Then push the "plus" (+) button until your gear shows "8" for the tranny to go through all of the gears. When you first push the minus button your "gear" selection will show just to the right of the odometer.
Update: As my friend @mikeru pointed out, you'll have to do this everytime you shift the tranny into "drive"..
Wanted33
Down South in Dixie
5.7L
I think the Tow/Haul mode switched on will also disable eco mode.
I think you're right. Just wondering though, does tow/haul change the parameters on the transmission? I haven't tried it on my 1500, but I know it changed most everything on my previous F-150.
KDT1970
Grantsville
I think it may also stops the transmission from going into the higher gears.
mikeru
Super Moderator
Super Moderator
The Palouse
2020 Limited
Hemi 5.7L non-Etorque
It can be temporarily disabled using the gear limit switches, as described above by @Wanted33 . Tow/haul mode works too (on 5th gens), but it changes the shift parameters of the transmission, and it will affect fuel economy.
Actually, it's worse than that...you have to disable it every time you shift into D.
Wanted33
Down South in Dixie
5.7L
Funny you should mention that Mike. I just found that out Tuesday when I picked my truck up at the XPel installer. :)
Riccochet
Somewhere around Charlotte
2020 2500 Laramie Longhorn
It does not. Tow/Haul only changes the shifting strategy. It'll hold gear longer while accelerating and drop gear when brakes are applied.
Really, they should call it "Sport" mode as it keeps your engine in the upper RPM's where it makes the most power.
runamuck
dfw
6.7 dsl
my '19 laramie recently started to run in eco mode a lot more than it used to. yesterday at 75 on the interstate the eco light was on for most of a 60 mile run to another town and then also coming back. is this something to be concerned about.
Ondgas
Castroville Texas
345 Hemi
I wouldn’t think so. If your MPG is consistent, that’s a good sign the engine is running good. If MPG drops, something needs attention.
woojyee
Nebraska
Hemi 5.7 eTorque
Yes, move to Nebraska and the wind will make sure it never comes on. It will also help keep the tranny from shifting into 8th gear, so you get a cool 10 to 12 mpg!! :favorites68:
Vehicle Probes
4077 My Drive, New York
5.7-liter Hemi V8
To permanently turn off the Eco Mode in your Dodge, particularly for the 5.7 engine, you can follow these steps based on the guidance from the Vehicle Probes article (ECO Mode Disable Permanently).
  1. Locate the Eco Mode Button: Find the Eco Mode switch on the instrument panel near the gear. It’s typically labeled with "ECO".
  2. Deactivate the Eco Mode: Press and hold the Eco Mode button until the Eco Mode light turns off, indicating that the system is deactivated.
  3. Confirm Deactivation: Start the engine to ensure that Eco Mode is truly disabled. You might want to drive for a short distance to check if the system does not reactivate automatically.
For a more robust solution, consider using a tuner such as Diablosport or an HP tuner to adjust the vehicle’s settings. This method will permanently disable the Eco Mode at its core, effectively preventing it from reactivating during regular operations. This approach might impact fuel economy and increase emissions, but it will enhance power output and acceleration response for your Dodge.
