Fitting 285/60r20 on RWD
97magnum
5.2 Magnum
Hey folks,
I am looking to fit a set 285/60r20 (33.5"x11.25") on my RWD Ram 1500 regular cab with a 5.2 Mag
What do I need to do? I am looking for the most budget friendly way.
Here is what i was thinking, 3 inch leveling spacer up front and maybe a 1 inch block in the rear so the front doesn't sit higher than the rear. Will that work? Will I be a OK with just a 2 inch front spacer?
Any helps and input will be greatly appreciated
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
Usually a level will take care of that.
DodgeTx
SEGUIN
5.9L Cummins, 5.2l v8
you can run those stock height, they will just rub on turns and some bumps.
97magnum
5.2 Magnum
So just an update...
I installed the tires and they fit fine but did rub at full lock, so i went ahead and ordered a 2 inch leveling kit.
Now does anyone know what the ideal gearing for my rear end should be?
5.2 Magnum, automatic transmission with overdrive...
Gr8bawana
6.7 CTD
It's hard to go wrong with 4.10 when running 33's.
