FYI Window Washer Fluid
Idaho Dave
idaho
6.7 diesel
Purchased Rainex all Weather washer fluid and filled the reservoir. Sometime later was on a trip and it was getting low, topped it off with regular washer fluid, after a bit my washers wouldn't work, pulled the tank apart and low and behold the Rainex had turned to snot, so I guess it's not compatible with the standard washer fluid. Comments?
tron67j
Maryland
Do a search in the forum, lots of discussion on this. Have to use only approved type, suggest OEM fluid.
Rlaf75
East Hartford CT
Ive used rain-x in every vehicle i owned including both my rams and rain-x washer fluid is the only fluid I'll use. I never had a problem with it ever
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
one type of Rain-X will eat up plexiglas, just ask a motorcyclist that has been riding for more than a few years.
One type of Rain-X does gum up Ram windshield Washer Pumps
Some Rain-X works perfectly in the Windshield Washer Reservoir
There have been more than one conversation on this forum about it
Dodge 1500 4X4
Rochester, NY
Don't use any Rain-X product, only use the blue stuff, or OEM there is an additive called Heet antifreeze to bring it down close to O Fahrenheit to prevent freezing.
Tomkay44
Lumberton, TX
6 CYLINDER GAS
I let mine run dry in my 2020 1500 because they never top it off or tell you it's low when they do the alleged 24 point check when I get my oil changed at the dealer. Bought Rainex because it was basically the same price as the blue, filled it up, and now, everything sounds great when I press the washer fluid button with my truck running but nothing comes out. It also leaks a bunch but only if I run the washer. Everything that's supposed to go on my windshield leaks out at the reservoir. It doesn't leak if I don't run the washer.
NETim
Nebraska
5.7L
I only run the purple -30F stuff. Whatever brand Menard's sells. Works good. Never had a problem.
