Gladiator rear sway bar end links?
GRKN
I have 2" rear coil spacers in my truck and looking to level out the sway bar. Was looking at the core 4x4 end links but came across a pair of synergy gladiator adjustable end links for a little cheaper, since I've heard gladiators have basically identical rear suspension I don't see why they wouldn't work? The length checks out compared to stock. Here's the link
Then another cheaper option would be these drop brackets also for a gladiator, but I don't know if they mount to the frame the same between the gladiator and ram? https://www.synergymfg.com/synergy-jeep-jt-rear-sway-bar-drop-brackets.html
Apologies if this has already been discussed but I couldn't find much about rear end links for rams at all. Just wondering if anyone has tried this or knows anything about it.
DILLIGAF
Canada
Should work no problem :cool: just make sure the length work for your application !
GRKN
GRKN
Thanks for the input. Yep, stock measures about 11.25” and synergy says these are 12.75” collapsed and 13.25” extended so should be perfect for a 2” lift.
